This is the dispenser
I just had this problem come up this morning. I turned the machine off, then started again. It works fine! This is what my Maytag looks like.
I just spoke to a repairman who claims he's been working on Maytag washers for twenty years and has never heard of an F-30 error code. He says all Maytag error codes are four digits, and this isn't a real thing. Like I'm lying. While he's saying this, I'm watching the F-30 code flash on my machine. My God, you can't find anybody who knows how to fix anything any more...
SOURCE: kenmore elite he5 - error code F30
F 30 code can be reset by un plugging power cord for 5 minutes also pull out the detergent dispenser and reach all the way in to the back there is a small plastic flapper valve move it from side to side with your finger this will rest code f30 and save a tech visit..
SOURCE: My Whirlpool washer flashed F30. Not filling up with water.
"F30" indicates "DISPENSER SYSTEM ERROR"
When the dispenser motor cannot be driven to its proper position this error appears in your washer. To fix this problem follow these procedures.
1. Unplug washer or disconnect power.
2. Check mechanical linkage from dispenser motor to the top of the dispenser.
3. Check wire harness connections to the dispenser motor and Central Control Unit (CCU).
4. Check dispenser motor for powered rotations.
Thank you !!
SOURCE: F30 error code on whirlpool front load washer ''Duet''
You have a problem with your soap dispenser. This has been a very common problem. You need to order W10161052 Actuator, W10157886 Dispenser, 8183186 Actuator Motor. Put these new parts in and you will be fixed.
SOURCE: F30 code
F30 = DISPENSER SYSTEM ERROR
You might have to replace the damaged one.Or in other words something that cannot be repaired.Well came across this info through other certified websites.good luck.hope this helps out.
SOURCE: Mt he3 kenmore washer is flashing a f30 code, what
This is a common error code with this machine. On this type of symptom
you will need to ohm out the temperature sensor probe. If the temp
sensor is good you will need to replace the EOC, electronic oven
control and it is much more expensive. The temp sensor can be accessed
& removed from inside the oven.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
