Sounds like hard drive fail. take the hard drive out and put on a PC as a slave setting. if the PC picks it up, if it does go to my computer and check hard drive for faults using windows tools the hard drive should be in FAT32. if it will not read in window or ask's to be formated. it has lost is FAT32 format. now it can be remormatted but you will need a FAT32 format softwear as windows dont use this now in there firm wear. down load the firm wear from dedicated micro web site. and put the 3 files on the hard drive boot folder zip file and another one cannot rember name not dv file think it say or the not pad just the 3 files. put hard drive back in as master again. and turn on it should restart. will take a bit longer as it will be opening the zip file and loading the softwear. when its done then you can sort out the setting in the menu etc for record etc.if hard drive has failed and no repairable format it 2 FAT32 and do as above with 3 files. should be fine then. allso in the site is a manual read this for the setting.... think 6019 is hard drive fault
SOURCE: Hi everyone I have one ECO4
Hmm, this definitely sounds like a storage problem. Did you just turn it on one day and find this error, or was it right after doing something on the unit?
Thanks
Tim
SOURCE: Disk Problem - may be
Ok, after trying to find a solution to this problem, I found out that the problem is that the Hard drive is dead. There is nothing to do besides replacing the hard drive. Dedicated Micros recievers company is located in UK. I am waiting an answer from them if there is a hard drive replacement available. I'll let you know if I get to fix this recorder.
