I have a mackie 12 channel mixer, but don't know how to use it while recording. I want to run it in conjunction with my m audio interface and recording software (logic); how do I go about doing this?
Sounds like the output cable from the 802 is not correctly pinned to your input on the computer. Fred is on the right track but you may need to take it a bit further.
It may also be helpful to use a Pro USB audio interface such as the Digigram UAX220v2 (line level version).
If you wish to use the computer's on board sound card consider an IHF/Pro interface that converts balanced audio to unbalanced , and the proper cables. Two 3-wire balanced 1/4-inch from the 802 to the left and right inputs of the interface (XLR Male), then RCA (Red and White) to a 1/8-inch TRS Plug cable onto the the computers audio input.
Henry Engineering's Matchbox HD comes to mind.
Good Luck.
That's basically normal actually...however it depends on which aux send you're using. If you use aux 1 for the effects, you can use the pre/post switch on the master aux 1 send to switch it to pst fader....now your mute switch should kill the effects as well. Aux 2 is good to use for monitors where you don't need to return them to the mixer.
The problem is that card has only UNBALANCED inputs. You really need balanced or first run the mixer outputs through a DI backwards. Frankly, I would recommend NOT using a card within the PC as there is so much digital noise. Use either a USB or Firewire external convertor and for goodness sakes use balanced lines from teh Mackie... ALL interconnected equipment needs to be powered from the same receptacle or source. M Audio, Roland/Cakewalk and Presonus all make cards as do others.
The internal audio systems in the PC's are inadequate for high quality work. You should get an external audio system that attaches via firewire or USB to your MAC. Then use balanced cables from the mixer to this audio interface. There are MANY different audio interfaces... Search the music equipment suppliers in the "recording" section of their catalog...
Using two balanced lines either TRS or XLR depending on what is on your M audiointerface, connect the L and R main outputs of the mixer to the L and R inputs of the M Audio. You will need recording software on your computer.
Use TRS to TRS balanced cables from the M Audio to the line in 11 and 12.
Set the pan controls for the 11 and 12 to opposite directions to split the stereo to left and right main outputs. (otherwise both main outs mix the left and right and you get mono result.
