Question about Asko W640
Asko W640 water outlet fault
Hi, i am having the same issue with the water outlet fault. Did you find out how to fix the problem?
  • rkeizer Nov 19, 2008
    I have exactly the same problem.
    I can do 3 washes and then I get Water Outlet Fault.
    I manually empty the water, check for blockages, ensure everything is clear and sometimes it washes and sometimes I get the problem and we start over again.
  • Anonymous Feb 01, 2009
    Same problem here. I have to baby sit the machine everytime I do laundry, and up washing a load two or three times.
If you get the water fault after checking the lower drain, you may need to remove the drain hose in the back. Usually there is a dime in the hose or the hard part right before the hose.
Posted on Feb 27, 2009
    Problem Solver:
  • 8 Answers
Sorry still waiting for my problem to be resolved, ended up buying a new machine....
Posted on Sep 11, 2008
6ya staff
SOURCE:
We have a problem with our W640. The power shut dowm every time we put the contact in, and we cant open the door bacause of the power. is there any buttom i can push? and were is it?
You can open the door manually: Open the filter flap at the bottom left of machine- you will see a red loop attached to the machine by a screw- remove this screw and pull down on loop- door will open. If you go to www.asko.com.au, click on "customer care", then "manuals", and type in "W640" in the "Search product" box, you can download the entire manual for your machine. Chapter 13 has picture showing how to manually open door. However, if the machine is tripping the power when switched on, you obviously have some electrical fault in machine, which will require the attention of a technician. At least you can get the clothes out though!! Happy fixing!!
May 11, 2010 | Asko W640
Violent spin cycle
Did you remove the shipping bolts?
Apr 27, 2009 | Asko W640
Asko w640 has a water inlet fault
Check the drain line to make sure the water does not siphon out as it enters the machine.
Mar 10, 2009 | Asko W640
Asko W640 - sporadically says motor fault and won't run, or, won't stop running, gets stuck on the spin cycle. We've had the motor fault problem before, but this "running on" issue is...
I would say the won't-run problem is separate from the run-on problem. You can live with the run-on problem -- probably a fault in the controller. Unless it's a faulty code, the motor-fault light probably means the motor is overheating. That can be caused by anything that causes it to work hard, such as a stuck pump.
Nov 26, 2008 | Asko Washing Machines
Asko
Hi, I am in NSW, worked in Sydney branch until 2005, now run service business in Blue Mountains.
I posted that solution as a bit of fun, stumbled upon this site the other day while researching reviews of other brands of white goods and the problems people have and complain about.
Which state are you in and working for? I am happy to share ideas etc,,,do you work with other brands as well, or soley Asko?
Oct 09, 2008 | Asko W640
W640 - Water Outlet Fault
I solved this problem this morning, after several months with intermittent "water outlet fault" error messages.
Our pin trap was cleared many times over the months. The propellor turned freely. However, the problem persisted.
So I unplugged the machine, removed the back panel (8 or so hex screws) and located the point where the drainage hose meets the water draining pump. I then separated the hose from the pump and found 2 United States 10-cent pieces lodged together with gunk that effectively blocked the drainage hose. 10-cent pieces ("dimes") are the perfect diameter to get stuck there and not appear in the pin trap where you could easily see and remove them.
Three loads later, the machine is working according to spec. Hope this helps.
Apr 09, 2008 | Asko W640
Fault indication: water inlet fault
see if there is a blockage in the level switch. the switch operates on air pressure within the dip tube and the diaphragm in the switch. there may be a spider's nest in the tube or a wasp's nest in the tube.
Feb 03, 2008 | Asko W640
Asko W600 spin cycle not working
Check the brushes oin the motor. It's the most normal fault when this problem appears. Not a big thing to fix for a technician!
Sep 24, 2007 | Asko W640
Wash motor fault
We got the same problem 2 weeks ago. Overode it by swiching everything off and then back on, wish we hadn't as te machine stopped washing 1 week later. Motor has gone $300 and it took the electronic controler out as well $300. Labour $100 plus call out $95. It'sa serious falut and should get it fixed which begs the question why have fault indicator ro this problem if you cna overide it. In addition you probbaly have a minor water leak from above the motor, which can be fixed with silicone. Asko saya it's machine lasts 20 years, think again as for a $1900 machine very disappointed. Australia
Aug 23, 2006 | Asko W640
Washing Machines Logo
2,355 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
ROB
Lollo Pop
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
