Canon PIXMA MP620 All-In-One InkJet Printer Logo
A
Anonymous Posted on Sep 01, 2011
Error code C000 comes up after every print, and only one page can be printed per command. To get the one print per command I have to unplug the printer after each print.
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Sep 01, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
9784
Points
15
Rachel Bilson
Level 2:
Habit-Forming:
Scholar:
  • Canon Expert 45 Answers
  • Posted on Jan 20, 2020
Rachel Bilson
Canon Expert
Level 2:
Habit-Forming:
Scholar:
Answers
45
Questions
0
Helped
172156
Points
152
Method 1: Removing of all packing materials Sometimes the error c300 code is caused due to not-removed packing materials. After doing so, check whether the issue still persists or not.
Method 2: Fixing all the ink tanks properly Another reason that might cause this error to occur is poorly seated or unseated ink tanks.
Method 3: Checking for Empty Ink Cartridges Many times, canon printers show the error c000 when the ink cartridges are empty.
Method 4: Removing of Foreign Objects and Clearing of the Paper Feed Path The most general reason for error c000 is foreign obstruction or paper jam in the paper feed path of the Canon Printer.
I hope the above solution helps you in solving Canon printer error c000
Canon MX922 printer displaying code C000
Try switching printer off then unplugging the power for 15 or so minutes. If that doesn't work and same error pops up when you turn printer back on, contact Canon.
good luck
3answers
2answers
Why is Alarm code 5 flashes not going away?
This is consistent with any of error codes 1401, 1403 and 1405. It indicates a problem with the print head.
Per Canon the resolution of these errors 'requires the assistance of a Canon authorised service facility. Please use the link at the top of the page to locate your nearest facility.'
From Canon error page for 'Orange light blinking 5 times':
1401/E05
Description: The print head is not installed or has not been properly installed.
1403
Description: A print head temperature sensor error has occurred.
1405
Description: Faulty data of the print head.
http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/
C000 code error
i thnik you need to update its driver
4helpful
2answers
Canon mx860 - had an error code C000 and now a day later 306A
Error code C000. Cancel printing, and turn off the machine. Then clear the paper jam or foreign object that is preventing the Print Head Holder from moving.
For more information about the error code C000, can be read here Canon Support and Downloads
You read, the bottom of the page
1helpful
Hello, i have a canon pixma mp 540 x It give sthe error code C000 Have you got any idea what the problem might be.
Is any paper stuck before the error come out?
Turn off the printer, try to move the print head by yourself. If you can move it smoothly, maybe print head or the holder problem.
3helpful
2answers
I have riffile my smasung ml-1640 printer cartage three time then it show red light but printer works ok, after 2100 pages printed its not working properly, when i give command to print any file no error...
By deepak_compu on Oct 06, 2009
i have riffile my smasung ml-1640 printer cartage three time then it show red light but printer works ok, after 2100 pages printed its not working properly, when i give command to print any file no error show,but print not come. and when i print a test page from printer button it gives print. but on paper write like this toner exhoasted so what i do for this problem please give me soltuion of this problem
1helpful
Canon D861 copier
Garner,,, the C000 code is a fuser error code on this machine. It can "sometimes" pop up after a power surge/spike/loss event, and needs to be reset in service technician mode. If it doesn't reset, but rather comes back, you probably need a sevice call for something defective in the fuser (lamp, fuse, thermister).
IF YOU'RE GAME, here it is...
To enter service simulation: press"Additional Functions" to enter "User mode". Press # key. Press </> to select a menu item. enter new data using number keys. Press "Set/OK" key. Press Stop/additional functions to exit.
Note: To reset E000, E001, E002, E003, go to service mode 4. select SET, go to "#7 PRINT-ER," in service mode. Then press Execute "#4 PRINTER RESET."  Power the unit off/on.
old marine
old marine
ZJ Limited
ZJ Limited
