SOURCE: Broken front door
you need to buy a new 'handle'. to open the door for the time being, disconnect power and then use a coat hangar to pull the latch towards you, ie. outwards
SOURCE: cannot open door as handle broken for indesitw103
hiya easiest way to open is = first unplug power! then turn off water hoses to machine then draw machine out to gain access to pipe connections on rear and disconnect them ? now remove rear panel top screws as these also secure the top panel at rear then lift rear of top panel and pull to rear the panel now can be removed ? you now have access to the latch on front panel inside? if you reach down you can flick latch /hook clear to open door ? at this point after removing washing? you can observe the door inner remove inner panel that surrounds/secures glass? then you can observe how the door handle/lock assy is secured ? easy diy you can browse yellow pages for the replacement handle assy? machine repairs/spares reassembly is reverse to above wish you well this is a common occurance and should not have prob obtaining parts for the MAKE/MODEL NUMBER ? when enquiring for parts best wishes
SOURCE: Broken door handle for a Thor washing machine
there r 2 ways to get the door open 1)use a normal knife and place in front of the door handle push it in and it should open 2)pull the plug out take the lid off now place your hand down to where the catch goes into the washer using your fingers u should be able to pop it open with a bit off fiddling
SOURCE: door handle of washing machine broken
if clothes are still in washer? and machine has finished cycles? then handle broke so unable to open ??? your best option is to unplug/ and if necessary disconnect water supply hoses then remove the top screws from rear panel which also secure the top panel as you will observe ? then pull backwards top panel and loft off ? you now have access/visual of the door catch inside front machine look?? at the catch and you will see how it locks ? you can lever the catch gently and door opens to fit a new door catch is easy diy and not expensive if you are confident usual problem these break ? is the time delay micro switch sticks with age /moisture try dw40 and work plunger b4 you refit door back after replacing handle/catch assy
SOURCE: j845 washing machine door won't open
1. Unplug the power cord from the outlet.
2. Remove the front lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about quarter inch or until a click is heard.
6. The door may now be opened. Your door lock is broken; actually you have to wait 2 minutes after the wash is over to try the door. If you cannot have access through under the machine, you can try through the top. Some models have a cord behind the dispenser tray.
Sites for spares.
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
