i have a goodmans GTVL19W17HD T.V and a Nvidia 8500GT graphics card, my monitor only supports VGA and HDMI and my graphics card only supports VGA AND DVI so my question is if i buy a DVI TO HDMI cable will the picture quality come out HDMI Quality or DVI quality? please reply asap i really need help with this. THANKS.
ok thanks so much now atleast i know if i buy a dvi to hdmi cable it will be high definition THANKS SO MUCH.ok thanks so much now atleast i know if i buy a dvi to hdmi cable it will be high definition THANKS SO MUCH.
You can't post conmments that contain an email address.
When using a PCI or PCI-E graphics card, it will disable your standard VGA output port because the up-dated graphics card and your factory VGA port require different display drivers. Usually, the drivers are conflicting and will make your system unstable and cause it to crash. In short, you can't use both at the same time. I have a Radeon HD 5450 graphics card installed on my PC and it too has disabled my standard VGA port. If you are trying to use more than one monitor, you have to install a graphics card that supports a multiple display output. The graphics card will either have 2 VGA ports, 2 DVI-D ports or 2 HDMI ports or even any combination of the 3. My card, for example, has 1 VGA, 1 DVI-D & 1 HDMI. I can run up to 3 monitors at a time via my graphics card, but I cannot run a 4th monitor from my factory VGA port. My graphics card uses ATI/AMD drivers while my VGA port requires the use of Nvidia drivers.
I hope that you find this useful.
VGA quality only. If you want to release the high definition features of your TV, use high definition graphics card together with HDMI cable. Hope it helps. Good day!
Regarding your question if you will use a converter from VGA to HDMI will it provid High Defenition video?
I believe that it will provdie video converting the signal from VGA to an HDMI connection but I do not think that the video will be High Definition since the VGA is just being converted to HDMI signal and not an actual HDMI but just a converted signal, and it is possible that it may not work properly or the LCD TV may have difficulties recognizing the signal from VGA converted to HDMI.
If your screen has a VGA, DVI, or HDMI port, most of the new graphics cards will be compatible with your screen. Most graphics cards come standard with DVI ports and include a vga adapter for the screen cable. Some of the new graphics cards come with HDMI and DVI ports or a HDMI converter if you want to use HDMI.
I would recommend a Nvidia graphics card. Depending on what your primary use is going to be they have an extensive range to cater for your requirements and price range.
