Panasonic PV-GS35 Mini DV Digital Camcorder Logo
Posted on Sep 11, 2008
Panasonic PV-GS35 camcorder
I have bought this camcorder but without the disc, I have downloaded the DV motion picture software from panasonic, but everytime I connect I get message there is a non PAL device connected and it shuts down, what else do I need to do?
  • blirio Jan 19, 2009
    SAME PROBLEM.NOCD SOFTWARE
A
Anonymous
Is you camcorder pal or ntsc?
1helpful
Does my Panasonic PV-GS35 Mini DV Digital Camcorder have a VCR mode and how do I access it? I am trying to copy a VHS tape to mini DV and I cannot get my camera to do it.
The Panasonic PV-GS35 will let you record digital media to the mini DV cassette if the other video source has a DV input/output connection. Then you use the 4-pin to 4-pin Firewire DV cable, PV-DDC9 . This cable is available from Amazon, https://www.amazon.com/LETO-FireWire-Panasonic-Camcorder-PV-DDC9/dp/B00MLQVMSK , and other vendors. The digital camera doesn't have the S-video input needed to record from most other sources.
For information on the digital dubbing feature, see the manual starting on page 42. Panasonic has the manual on the product support page: https://shop.panasonic.com/support-only/PV-GS35.html . The current link to the manual is ftp://ftp.panasonic.com/camcorder/om/pv-gs19_en_om.pdf . See page 13 of the manual for the location of the DV port.
I hope this helps.
MY VIDIO CAM SOFT. CD HAS CRACKED SO I WANT DOWNLODE SAME SOFTWARE.
You can download the software and drivers from the panasonic support page for your product, I'm posting the link to the page below.
http://www2.panasonic.com/consumer-electronics/support/MiniDV-Camcorders/model.PV-GS35
2helpful
I lost the disk for my Panasonic PV-GS35, where can i get the software from that disk?
You can download it from the below link:
http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Camcorders/MiniDV-Camcorders/Drivers-Downloads/model.PV-GS35.D
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
The lcd screen has stoped working om my panasonic pv-gs35. the veiw finder still works. is there a mode i changed or any idea whats wrong...thanks, kyle
HELLO! IF YOU MOVE THE LCD SCREEN BACK AND FORTH AND YOU SEE PICTURE FOR A SECOND THEN LCD HINGE MUST BE REPLACED,IF NO PICTURE AT ALL MAYBE PROBLEM ON LCD BOARD.
1helpful
Camcorder as source for video software not found
if you have a nv-gs35 i am pretty sure that ths camera can not do video transfer via usb, the port is not usb2. it can transfer video via the dv port only. please check the operating instructions.
4answers
Detect
you cannot get video off the tape with a USB cable, you have to use FIREWIRE
Can I have a driver for panasonic pv gs35 driver vista?
You don't need a driver. Just connect the camera using the cable provided with it; turn the camera on and set it to play movies. The first time it will upload the necessary drivers. THen, use Windows movie maker (it's included in vista, my version at least) to import the movie (if you don't find it, click on the start button and type "movie" on the search box). It's much better than the crappy software provided by panasonic anyways.
PV GS 35 wont play tapes from other cameras
perhaps it has to do with the SP and LP settings, I know certain video editing programs won't capture video recored in LP.
Top Panasonic Video Cameras Experts
NOEL
NOEL
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
