Hi thanks for the question ,YEs i can tell you how to remove the clutch Remove front panel .Motor is held in place wiyh 4 3/8 nuts underneath the motor remove the motor .The clutch is held in place with a spring clip at the end of motor . Remove clip Now the clutch should come off thanks for the question
Hi Docjohn
Thanks for the reply
Got the motor off, took off the snap ring on the clutch, the outer section of the clutch came off, but the inner section of the clutch is still on the motor shaft. I tried hammering the shaft out but can only get it part of the way off ( up to the key) Any suggestion how I might get it completely off? or are you not to take it off. I looks like a press fit at the factory.
