SOURCE: Samsung Plasma TV
I have been having the exact same problem. TV on for 30 min with terrible static, then all of a sudden it is perfect again. I've also inherited a bit of a humming noise from the tv as well. It was suggested to me in this forum to have a tech come and adjust the v_scan and v_set settings down a few mhZ. No idea what this means, but I assume it's a power setting and the tech will be able to take care of this. I will post my results when i have the tech in.
SOURCE: Black Screen after 5 mins. of use
It sounds like the entire screen goes blank with your problem. My problem is the lower half of the screen goes blank. Do you think the SSB is also the problem? What are your thoughts about the "Video Board" or the X Board?
Do you know where to purchase parts?
SOURCE: Won't turn on blinking red where green power lights should be.
plase open the cpu & plug in the ram in the right order.
SOURCE: hp xw6200, 6 beeps, and red power button...failed start up.
6 long beeps indicates that there is a problem with the memory, take them out, clean the contacts and the DIMM slots and reseat them.
Hopefully this will resolve the problem, if not new memory may be required
kind regards
SOURCE: nx6310 wont stay on
HP is notorious for this problem. The problem is that the power jack that is connected to the motherboard has come loose. This is an easy fix is you are comfortable taking apart your notebook and are able to solder the jack back to the motherboard. I have 2 HPs and my friend has 2 and we have done this with ours as well as others. This is the link to the HP website that has your manual for disassembly .http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=101&prodTypeId=321957&prodSeriesId=1839143 When you get to the page, download the Maintenance and Service Guide. (It is all the way at the bottom!) You will need Adobe Acroabt to read it. PRINT the instructions. They will do you no good if they are on the laptop that you are trying to disassemble!
While it may seem daunting, it is really not hard to do. Just be careful to follow all of the disassembly and reassembly instructions and you will have no problems. I promise!
Please remember to rate my solution! Thanks
