It sounds like your charger is faulty. Try to measure the voltage of the batteries. If the nominal (workingh voltage of the batteries are 19,2 volt, then they should invrease to about 22 volt while in the charger. If the voltage does shoot up when the charger is on, maybe even to 25 volts, (which should turn the green light on) the new battries are dead!
It happens!
The other possibility is that the batteries are OK & fully charged!
But!
Your sander is damaged. Again, try & measure the voltage in the sander, before & after you switch it on. A large drpop in voltasge can indicate the sander drawing too much current. Also try them in another machine if you can.
Andy
