Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I installed a Craftsman garage door a couple of weeks ago and all of a sudden it keeps opening by it's self. It is model #139.53918D what is causing this?
    President:
  • 3,197 Answers
Make sure the door isn't closing too far. This will cause it to open. Your opener comes with a warranty. Call Sears repair.
Posted on Sep 06, 2011
6ya staff
SOURCE:
Craftsman Garage Opener intermittently not closing
A couple things to check and do. If the main light flashes 10 times when the door reverses to the open position it is a door sensor problem. Make sure they are pointed at one another and that the small light on each one is lit and not flickering. Tweak them a bit if necessary.
If the main light isn't flashing it may just be a simple adjustment. Locate the 'down force' adjustment on the rear of the motor unit near where all those white wires go. Increase this about 1/4 turn and try.
For the light you should unplug the unit and then using a small screwdriver pull out on the center contact in the light socket.
Nov 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Motor wont run on craftsman opener
You need to remove the cover and look at the drive gear. It is probably stripped. I really recommend a technician to repair your door.
May 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door opener won't close completely
look on the side of the openeer usually lekt looking at it from the rear theese are your travel adjusters one turn = 2" travel normally
Jan 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Liftmaster garage opener model #114OLM
when you are programming , how long do you push LEARN button for, If you push for 6 or more seconds, you are wiping out all code, Push for 1 second to add a remote or keypad,
Jan 24, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
136 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
