Do one thing Go to the menu of the tv. Select Picture setting and then select Advanced video and select Zoom mode. In zoom mode select Wide. If you hve already done this ,
Then select the Overscan option in the same menu page and select it as ON .
Next one select Auto zoom in the same menu page and select it as OFF.
OK
hi,
Check one more thing Go to the MENU and select SETUP. In the setup menu select RESTORE DEFAULT and and restore all setting to factory setting. When you do this you will loose all the channel settings. After reset you have to retune the tv to get all the channels. If you are using a cable receiver externally then check is there is any picture setting in that.. OK
hi,
Now do the following again to set the pictuer as wide screen . Select Picture setting and then select Advanced video and select Zoom mode. In zoom mode select Wide. If you hve already done this ,
ok
hi, Select the channel which is not in full screen. then goto the menu and then do setting as my first comment to set that channel as full screen. Do this with all channels which is not full screen. If it dosent help then there is problem with the software of you tv. To upgarde the same you hve to consult the autorised servicing centre.
ok
hi,
There is problem with the software of you tv. To upgarde the same you have to consult the autorised servicing centre. ok
hi,
As you wish. Try to Inform fixya that your problem is not solved.
ok
This worked for me. Thank you sooo much!
I tried all that before and it didn't solve the problem. I did it again as you suggested and it still didn't solve the problem.
I did that and it gave me a picture that covered about 3/4th's of the screen
I did as you suggested and I still get some channels that are not full screen.
I did that and the channel that is not full screen is set to your first instructions. Will not work
It looks like I will have to keep using the TV with this condition. I don't want to pay the manufactor big bucks to try and solve the problem. I assume your service will not charge me as the problem has not been solved.
