HP Pavilion MD5020N 50" DLP HDTV Logo
Posted on Sep 04, 2011
Md5020 hp Pavilion TV. Last night it started making a loud almost grinding fan sound, and the red lights started to blink in the light indicator patch. the light is going from left to right across the screen. What could be the problem?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 11, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
150
Points
1 Related Answer
Anonymous
  • Posted on Dec 31, 2008
SOURCE: Grinding Noise
sounds like you have a problem with the cooling fan
Pc won't start and makes 4 beeps and 4 red blinking lights.
ok we got a model
HP EliteDesk 800 G1 SFF rebuilt
generation 1, 2013.
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
3helpful
3answers
KDS50A2000 Green light comes on briefly followed by red blinking light. 4 on then pause, etc. etc. Problem???
I tried this solution last night. had a similar issue. opened up the back panel and cleaned the fan. just for the fun of it, i tried to turn the tv on and presto. it works fine now and i probably saved a bundle. thanks!!!
No picture or sound
Hi, your color wheel needs to be replaced, the bearings fail causing the grinding noise, the new ones use "air bearings" so they are supposed to last much longer, video-tek
No picture and no sound
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Grinding Noise
3answers
Blinking red light
I DO HAVE THE SAME PROBLEM , ONLY THE RED LIGHT BLINKING ,NO SOUND NO PICTURE '
PLEASE I DO NEED HELP TO FIX IT .THNKS
REPLACED LAMP STILL NOT WORKING
The fan problem appears to trigger the 4 blinking red lights to indicate overheating. The large fan just left of center when looking at the back of the TV is usually the culprit and you can confirm it is not working by shining a flashlight through the back of the TV. If the fan isn't turning you should consider cleaning. Otherwise you have another problem and should seek professional assistance.
Kds55a2000 red light flashing
The SONY Owner's Manual for the KDS55A2000 does not state what the 4 times blinking Power LED means.
However, my Sony Extended Care Service support insists that the projection lamp is the cause for the 4X blinking LED
Power light.
I do not agree but am forced to buy a replacement lamp (not cheap) to prove that the problem is probably the fan, as the TV Technician states elsewhere in these FixYa support questions and answer
Top HP Televison & Video Experts
 Mikey
Mikey
Stan Ford
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
