Well first of all Net books are kind of tricky because you have not DVD drive so most are loaded with a hidden factory partition in it, the commands to recover your net book are ALT F10 but if you are running vista or win 7 start the machine and during start of strike the f8 button this will boot you into the advance start up menu, choose repair my computer after that you will get a list of recovery tools. choose factory restore out of box or something to that affect. If your recovery partition is still intact the net book should start the process of re installing windows and all your drivers to out of the box condition. For XP users restart the net book and during the splash screen hit ALT and F10 at the same times several times and that will automatically invoke the recovery partition. . Hope this helps.
SOURCE: what are the key button
if the netbook is setup like the normal notebook, usually the F10 key starts the recovery process.
SOURCE: my rebooted my advent 4211-b netbook to factory
Welcome to Fixya
Error means the boot files are missing or damaged. Try to restore the computer using the disk that came with it instead of using the recovery console.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
SOURCE: I WANT TO REBOOT MY NETBOOK
Reboot the computer and as soon as it turns on start tapping F9 repeatedly. Do this immediatly after hitting the power button. If Windows Starts to load - you will need to reboot and retry.
Hitting F9 should take you to the recovery partition option. If you select to run it - it will erase everything on your laptop and set it back to factory defaults.
If you have more questions, consult the manual that you can download here: http://support.asus.com/download.aspx?SLanguage=en&p=20&s=1&m=Eee%20PC%20R101&os=17&hashedid=GhBUCjHj4BRr7ndV
Hope that helps!
Go to "Start" > "Restart" to reboot your netbook.
Hold down "Alt" and "F10" when you see the Acer logo on the screen. The recovery menu will load.
Hit "Enter" and then "Next" to see your recovery options. Choose "Factory Restore" to set your netbook back to factory settings. Follow the instructions on the screen.
Choose your time zone and language when the customization menu appears. Reboot the netbook when you are prompted.
Restore your saved files from the flash drive.
hope this helps
hope this helps
