If you have a Whirlpool oven, the F2 E6 error means that the Cancel key line is open. You will need to replace the keypad or the keypad and controller board (if a single assembly) if the keypad doesn't respond to a press of the Cancel Key.
This is a common failure of the control board. It is often accompanied by a intermittently blank display. The board is no-longer-available but we can rebuild it for you at www.fixyourboard.com.
F2 - E6
Cancel key drive line open
1. Check keypad connector for firm connection (keypad connects to control board). 2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Hello,the error E6 and F2 you are receiving could be describe as "Cancel Key line open".Follow the following steps 1. Check keypad connector for firm connection(Keypad connection to control board). 2. Press CANCEL if error code returns after 60 seconds,replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replay control board (also called ERC or clock). TThanks
When this code appears and display is going blank too, it is always the control board. The only option is to buy a new one or get it repaired. It can be fixed quickly and reliably. www.fixyourboard.com
