Express Appliance Repair Winnipeghttps://www.expressrepairwinnipeg.ca > general-electri...
If any wires are exposed or damaged then your temperature sensor is misreading your oven's heat which causes the F2 error code. If you have found any damaged or ...
"); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: 62px;"> Rating: 4.5 · 950 reviews
Missing: 326B1230P001 ' Show results with: 326B1230P001
this error for GE means that your touch control panel has shorted and the entire touch control panel would need to be ordered and replaced if resetting the circuit breaker won't reset the issue.
U have a bad clock or your probe inside of oven is bad.I would replace your probe first .it looks like a rod sticking out inside back upper top .f7 I believe means its not reading up temp and getting to hot
Hi Thanks for using FixYa. Error F7
means that the function pad button is stuck or the clock has gone bad. If you
are unable to unstick the button then to resolve this issue you’ll have to
replace the electronic range control. Please do rate the solution
if the issue is resolved or post a comment for further assistance. Thanks Rylee
F7 stuck keypad Stuck keypad may mean relay is turned on. Determine if problem is with the Key Panel or Control by: 1. Pushing CLEAR/OFF pad. 2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
I have a GE JT950 double oven that just did the same thing: F7 and beeps like crazy. I found solution on another post: an engineer figured out how to solve the issue without calling GE or buying parts. I just did it tonight and it worked fine. Here is a copy of the post:
Send an e-mail to Charlie at [email protected] for a fix-it that you can try. He explains a possible solution fully with his 'The Dreaded "F7" Error' solution. I actually found his information on another website when I did a web search for "GE Profile Oven F7 Issue". I sent an e-mail to him and he replied with free fix-it information. I am not a repair person myself, but, his instructions are very clear and simple to follow. I did the fix-it at no cost in approximately 10 minutes and it has solved my problem
