The Tv was made in 1999 so its not THAT old. The sound just stopped the other day. Without any indication that the speakers were going out. No static no nothing. Just stopped. There is no Audio Menu available in this model just language selection. Have Any TIPS?
I just had this happen and it was followed by a "fire" inside the box! I pulled it apart and found that the amplifier was melted. I have taken it out(do have experiance with soldering) and just need a replacement part...anyone know what/where to get this?
If theres a headphone jack plug in a set og headsets. if the sound is there then you know that your speaker is bad. if its not make sure the volume indicator goes up and listen closely to the speaker. Do you here static noises?? NO? ok then its a problem with the audio output IC built in to the set and this is probably something you cant repalce unless your experenced with soldering printed curcuit boards. If you here staic or a small his then the volume contrpl curcuit or the audio if is defective and this as well is not something you can diagnoise unless you know how to troubleshoot electronics. Good Luck
