Question about Sony STR-DE597 Receiver
My sony receiver is stuck in protect
This is the second time this has happened to my receiver, the first time it was under warranty. When I turn on the unit it clicks on and then a couple seconds later clicks and goes into protection mode. RThe unit is not really worth having it repaired, so I was wondering if anyone might know how to bypass the protection module. I dont care if the receiver blows up, as I will be upgrading within a year. Just hoping to get a little more use out of this unit. Thanks- Clayton Kirchhoff
  • 3 more comments
  • Anonymous Nov 25, 2007
    Sony STR-DE725 is doing the exact same thing. I tried tightening up all the screws inside, but ends up that didn't fix it either. Any ideas?
  • Anonymous Apr 05, 2008
    our Sony STR-DE615 will go into protect mode after a few seconds or a few minutes of operation. I've unplugged the unit and then plugged back in; I've also checked the speaker connections and they are ok--not touching each other or the back of the receiver.
    The receiver first did this suddenly while watching TV, so I know that no speaker wires had been changed or moved around, but I checked just in case.
    We are going to replace our whole system in the next year; meanwhile, is there any way to fix the problem now? I've read suggestions to take the back off the receiver and tighten all the screws/connections. Any other suggestions?
    jcg
  • Tim Kranz
    Tim Kranz Oct 23, 2016
    Unhook all speaker wires. Turn off and unplug. Wait about 15 seconds. Power back up without speakers connected. Check protect mode is gone. I just did that and it worked. Then unplug again and reconnect speakers. Problem should be solved.
  • Anonymous Sep 07, 2017
    I recently had this happen where my Sony Receiver went into protect mode. The receiver reset the speaker resistance setting to 8ohms (Perhaps from going into the protect mode or perhaps from a power outage). It's easy to forget that you need to set this.
    If you have speakers under 8ohms resistance, you must reset the receiver using the TV menu, settings->speakers->resistance to 4ohms.
    If you have a complex speaker setup then check your manual as to what setting you should use.
    I'm commenting because on my web search I came across this link and wanted to provide what solved my problem which was not listed.
  • Anonymous Jun 04, 2018
    I have Bose Acoustimass speakers and they pass through the subwoofer where the subwoofer would terminate an error before it reaches my receiver so I know it's not my speakers or wires. Also, all the wires were securely tight. Our house does not receive a clean current. Electricity seems to come to our house with spikes and drops. I know this because my computer is on a voltage regulator. That is what is tripping the switch in my ES Receiver. I bought a CyberPower UPS voltage regulator for under $100 and no more protection error! I am so happy I did not take my unit in for servicing or throw it away since the ES Series is not cheap!
    Plus it has the extra benefit if you are watching tv or playing tunes when the power goes out, it keeps playing with the battery back up. It is best to shut it all down at that point since the battery can only last for a short amount of time depending on how much you have on the battery side. There are plugs too without battery back up and they do support voltage regulation as well.
    I bought the CyberPower System AVRG750U. Good luck and feel free to message me with questions. BTW, Sony was no help in determining the cause. Their solution was to pay to get it fixed (nothing wrong with it) buy a new one!
I've had a Sony STR-DE725 for years, and it's always worked fine, until recently. When I turn it on, instantly, or within 1 minute - it will "click" and then display "PROTECTION". Like any good DIY'er, I googled everything - so I looked for any loose speaker wires, and finding none - decided to open it up. I pulled it out on my workbench, opened up the case, and blew out about an inch of dust from everywhere with an air compressor. Next I disconnected and reconnected every connection that I could easily reach. Finally, I unscrewed (about 1/4 turn) and re-tightened every single screw that I could reach in the guts of the receiver. It works fine now! Go figure... probably the dust, or a loose connection somewhere. Definitely try this first, as you have nothing to lose but 30 minutes of your time on a weekend!
Posted on Jul 08, 2007
  • Carrie
    Carrie Aug 24, 2018
    Thank you, this seems to have worked for my 10 year old Sony receiver.
I have the same problem. I took the unit apart and found the connection that was causing it to flash protect (no idea what it was). I left it unplugged and hooked everything back up and all works fine. I obviuosly bypassed something with the amp/ speakers. Kindof worried about blowing/ over heating something now. Any thoughts?
Posted on Oct 17, 2009
    New Friend:
I read a few of these and thought, how can tightening a few loose screws on circuit boards really do anything? But since I had to start somewhere I popped the cover off of my Sony GX69ES and tightened about 20 of the screws that hold the circuit boards down, plugged it back in and holy cow! No more evil 'P' flashing in silence! Thanks for the suggestions.
Posted on Feb 28, 2010
  • Bootlace8 Jan 01, 2011
    My 10 year old Sony STR-DE355 tuner/amp entered PROTECT after 5 seconds from swith-on. As well as tightening the back panel screws, I found that the chips which drive the output transistors had developed dry solder joints. After re-soldering the pins of the chips, no more problems.
  • Glen Ingalsbe
    Glen Ingalsbe Jun 14, 2016
    There are grounding pads underneath some of the screws on the bottom side of the circuit boards. Re-tightening them re-establishes a proper ground connection.
Kenwood receiver will turn off after a few seconds
Posted on Jun 21, 2009
  • Joel Mar 29, 2017
    Hi I have just turned on my sony 6.2 channel amplifier for subwoofer for 10 seconds it went of i checked it, it was a fuse. I replaced it after it went on but never clicks like usual and now there's no sound sins the clicking sound is no longer clicking, please help. I have a multimeter with me.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
I have had problems with my spare GX69ES going into Protection Mode for years. Every time I "fixed" it, it would be OK for a few minutes, hours, or even a day or two, and then go off again. I was thinking of buying a boat... I already had the anchor!
Instead I purchased a workshop manual *, so that I might figure out what was happening...
I measured the bias settings for the main amp. Sure enough the readings were way out. The in-balance was helping trigger the protection sensor circuit. I adjusted to the correct values and so far, after three weeks, Protect has not kicked in once.
Bias voltage should be 2.5 mV, measured on TP701 (near main heat sink), pins 1 & 2 for left and pins 3 & 4 for right. Adjust RV701 for left and RV751 for right. Speakers OFF, volume ZERO. Test meter reading will settle to value within 30 seconds of switch on.
*A great manual with full circuit diagrams, circuit board layouts and compponent lists. A bargain at $12.99.
http://www.service-manual.net/ashop/catalogue.php
Peter A
electronic(at)windstream.net
Posted on Oct 28, 2012
  • Maurice R
    Maurice R May 12, 2014
    Hi Peter A, I have the same amp witht same problem. When you did the test, did you wait for the amp to warm up and did you perform the bias test when the amp was hot or cold?
I had this problem continually until I upgraded two low-end speakers (4 ohm) to 8 ohms, which is the rating for my other speakers. Problem solved.
Posted on Aug 23, 2010
    President:
  • 3,130 Answers
Aws I said on the last post do not jump out the protection relay as your speakers will blow up and so may your house!!!!
Posted on May 05, 2006
    Novelist:
  • 130 Answers
I think i would rather figure out WHY its doing it rather then bypassing it. I dont think they just blow for no reason. To much bass? to loud? are the speakers stiill good? do you have a multi meter? what do the ohms read on each set of speakers? Speakers have limits even though they come with a system they can still be under powered. You would think the speakers could handle the system they come with but that usualy isnt the case. Hooking up more then 2 speakers can blow the amp, over heating (to loud for to long of periods, blown or shorted speakers) unplug all the speakers and try and turn it on, then one at a time hook the speakers back up.
Posted on May 06, 2006
    New Friend:
Protector with STR-DN840.
Repair tech : "it's too old (5y) so cannot get parts, too bad"
Tried the recommendation above : tighten screws, replug power cables.
It works fine again !
Otherwise I would have checked and replaced power amplifier output transistors, emitter resistor and base drive resistors (std electronic parts).
Also I found in the service manual :
PROTECTOR AUTO OFF To disable auto off after protector occur. Procedure: 1. While pressing display and movie button to turn on the main power. 2. “PROTEVER” appears and switch on the set.
Finally I found the real problem !!!!
Just the cable on the outside speakers.
AND
The PROTECTOR mode doesn't go off easily.
You must wait 30mn before testing each speaker (or open the unit, clean the dust, tighten the screws, have a coffee) to find which one is faulty...
Posted on Jun 19, 2019
  • Anonymous Jul 22, 2019
    I have the same model, STR-DN840. I found that it doesn't always take half an hour for it to reset from protector mode. I had already opened the unit, tightened screws (there weren't many to tighten) and cleaned out the small amount of dust inside. It still went into protector mode immediately when the speakers were connected. I use banana clips so there's no chance of wires touching behind the receiver. I decided to disconnect every speaker including the subwoofer, then reconnect them one by one, connecting one speaker then disconnecting it before trying another speaker.
    I found that all I had to do was press the power button to get the receiver out of protector mode. I didn't unplug it from the wall either. No more half hour waits between tests. I just had to turn the volume back up. Once I found the speaker that caused the receiver to go into protected mode, I reset the unit with the power button and then reconnected the suspect speaker to different plugs on the receiver (i.e. from "front left" to "front right") to confirm it was the speaker and not the receiver connectors. On inspecting the speaker I found that the black and red connectors on the back were touching. Since I fixed that - no more protection mode, at least so far.
    On a side note, some other posters have mentioned that it's possible to control the resistance of the speakers in the on screen Settings. Not with this model.
  • Sony Master
  • 2,010 Answers
Make open the cover clean print and all solderings before resolder the active components and loose solderings if there are active components look for brown spots especially after a long time of use on the print there can be little problems to measure or components fuse resistors or other components with loose paws and Tighten the screws of all the transistors that are mounted on the heatsink a little bit because after a long time they become sometimes loose because of temp changes over the years
Some capacitors can over time become deformed especially in the lower voltage range in the power supply for who is searching for a manual here is and use some contact spray for connectors and potentiometers . AND especially measuring and boldly go forward!!! reed?
SONY STR DE597 VER1 0 SM Service Manual free download schematics eeprom...
Posted on Apr 28, 2016
    New Friend:
If its goes to protection it means the power supply is OK .So try accessing the Amplifier circuit. Carefully take out the Amp I.C and then put back the system together, power it ON and listen carefully if the second relay switches ON. The problem is the Amp I.C and some burnt out resistor espacially 2.2 Ohms on the amplifiers output line .Replace the AMP I.C & resistors with a genuine parts or else u ll replace the I C everyday.
Posted on Oct 26, 2014
Check the resistance (ohmage) of the speakers and get one that match to your amplifier
Posted on May 15, 2014
Hi, I had this very problem with my Sony 5.1 home theatre amp - after a few seconds it would go into 'protect' mode and would not play sounds. Having checked all the usual causes such as wires/ shorts etc I took the outer case off revealing the 'workings' and just tightened up every cross head screw I could find. Since then it has been perfect. Might be that I had a bad earth???
Posted on Jun 12, 2007
You might have a grounding issue with the circuit. This could be caused by missing screws or screws that might have fallen out and are floating around in the case. I was recently repairing this exact system and it also went into protect. I opened it up to take measurements and quickly found out that all the screws have to be in place for the machine to operate. I put the missing screws in place and now the system works correctly. WIERD!!!!
Posted on Jun 05, 2007
My husband had a similar problem with his Marantz SR-68 receiver. After reading the above, he went to the back of the receiver and unplugged one cable at a time, and with each removal of a cable he'd test the unit. He had 2 speakers in the basement that were unconnected from the speakers. When cleaning, I must have bunched the cable into a pile. When he checked it out, both speaker wires were touching each other. After he separated the speaker cables, the receiver is working GREAT! The protection light is out, and he is putting caps at the ends of the speaker wires for his older style speakers. TpK
Posted on Mar 11, 2007
Usually stuck in protect without speakers indicates bad output ics. The amp is isolating the speakers from the bad outputs to prevent DC voltace from damaging the voice coils and crossovers.
Posted on Jan 24, 2007
  • Otie Jefang Oct 26, 2014
    tru Dat ! if you take out the Amp IC and then put back the system together power it ON if the second relay switches on .Replace the AMP IC with a genuine par or else ull replace the IC evey day
  • 32 Answers
I was having the same promblem with my receiver. I would disconnect everything and start over. Then I discovered it was the speakers. I had small speakers from another system. They were not big enough for the receiver. change your speakers!!!!!!!!!!
Posted on Aug 06, 2009
4 Suggested Answers
6ya staff
SOURCE:
ginko
Ginko
  • 19396 Answers
SOURCE: stuck in protect mode
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
Posted on May 29, 2009
ABRsvcs
  • 4234 Answers
SOURCE: Hot Receiver Goes Into Protect Mode & Switches Off!
The protect mode is a result of the heat not the cause. What is likely to be hapening here is that the amplifier is seeing to small a load. The amp is designed to work with speakers that are either 4ohms or 8ohms in impedence. An impedence load of 2 ohms will work but will cause the amp to work really hard and generate extreme heat. The solution to this is usually to locate speaker wires that may have crossed or frayed and shorted against each other. Were the amp to have a problem, you would not likely be able to get sound at all.
There is a possibility that the driver circuit within the amp is out of whack too. This could cause an imbalance internally that would also generate excessive heat. This is extremely rare, as this type of offset generally is caught by the protection circuitry.
Check the speaker wiring first. Next, if you have 2 speakers connected, only use 1 at a time. It is possible that there is a defect in the speaker where the laquer on the voice coil has worn away and the coil is shorting to the speaker frame intermittantly. If this is the case, the unit would behave differently depending upon the level of sound and the type. Also, it is unlikely that 2 speakers would have this problem. Disconnect 1 speaker and run the system for a while. If it works well, try the other. If a speaker is the problem, one of them should show the failure.
Please keep us posted.
Thanks,
Dan
Posted on Feb 17, 2010
Anonymous
  • 11 Answers
Speakers shorted out, blew a fuse. Replace the unit or (cross your fingers and) open up the box and find the blown fuse.
Posted on Dec 05, 2007
Sony tv picture goes green
HAVE IT REPLACE WITH A NEW ONE
Sep 12, 2012 | Sony Internet TV NSZGT1
Hi i am a new member and i have a problem with my str-k840p it started to have a protect mode flashing and I can't hear the at all the tv or speakers. What could i do i check all my connection and they...
Protect display indicates that receiver is in protection mode due to some serious problem in output amplifier section and most probably any output channel output chips got shorted out.
Protection mode turns On to avoid any further damage in receiver. If your Sony STR-K840P is under warranty then call numbers written on warranty documents to ask warranty cover and if unit is out of warranty then either Sony service center or local repair shop will help you to get it fixed, it is not user level repair.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Nov 29, 2010 | Sony Audio Players & Recorders
System Protect mode after a Flash fire.
The flash probably was a small resistor burning. While not particualrly common, it does happen. The output transistors are shorted and need to be replaced. If the same channel is bad as the first time, there is a possability that the unit was not completely repaired. Some shops only change the shorted transistor within the transistor pair. This is poor practice and usually leads to another failure of the same channel Check your previous invoice for the parts replaced. The entire complimentary pair of output transistors should have been replaced. If only 1 iof the 2 were replaced, you may have an argument for a warranty repair.
Please keep us posted on your progress.
Dan
Dec 10, 2009 | Onkyo TX-DS838 Receiver
Tv Turn sound on, No Picture, turns itself off within seconds
The TV is trying to go on protect mode because an internal fault had been detected. For that reson the protection circuit keeps turning off TV continuously.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
May 23, 2009 | Sony KLV-30HR3 30 in. LCD Television
Whenever a little bass sound - explosions, gunfire, helicopter blades, etc., ''PROTECTOR'' flashes on LED and shuts down receiver. Seems to happen more frequently lately. Subwoofer cable sturdy, no...
The protection feature on these units will shut off the receiver when there is too much power draw or when a speaker wire is touching another wire. First, check all of your speaker connections and make sure the wires are nicely twisted and inserted into the speaker and receiver with no stray wires touching. Secondly, if this doesn't correct the problem, try going into your speaker settings menu on your receiver and select "small" for each speaker. Let your sub handle the bass. The sub cable should have no effect on the protection feature of the receiver. The speaker wires, however, are the most common culprit of a receiver turning off (protector). Hope this helps.
May 03, 2009 | Sony Televison & Video
Receiver stuck in protect mode
surely i can reset this myself without paying sony!
Feb 01, 2009 | Sony STR-DE545 Receiver
Onkyo AV Receiver turning off - by its self.
The space you have provided should be enough. If this is a new unit and still under warranty, I would request warranty service. It sounds like the unit is entering protect mode. This may be due to heat or it could be because of a defect in the protect circuit. In any case, this should not happen that quickly.
Update this if not under warranty and I'll provide a list of diagnostic tests to help determine the problem.
Dan
Jan 16, 2009 | Onkyo TX-DS787 Receiver
Stuck in protect mode
Nov 23, 2007 | Sony STR-DE425 Receiver
Turn Power On and Off
The lens block assy gets dust collection, or subjected to jerks,blows,forced to act by pushing manually by children etc. Any abnormal usage causes problems like this. Servicing the lens block is the best solution.
Jan 18, 2007 | Sony Cyber-Shot DSC-P41 Digital Camera
Sony STR-DE597 Receiver Logo
50,173 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
