SOURCE: configure WRT300N wireless Router to connect internet using PPPoE
Often the nets and subnets are NOT the same.. ie The Fixed connection often uses 192.168.0.1, 192.168.1.1, however sometimes the wifi is setup 10.1.1.1, or 10.0.0.1 etc, have you checked this? Esentially tho ya router is an "Acess Point" and ya Lappy etc is ya "Client" the links below has a lot of tutorials to help have a look. http://portforward.com/routers.htm http://portforward.com/guides.htm
SOURCE: how can i unlock my router?
Ratrideen,
I'm not entirely sure what you are saying the problem is. Is it that you can't access the Internet from your PC once the netopia router is hooked up? If this is the case check your IP setting on the PC. The following documentation from the Netopia site should help.
Good luck.
J
http://www.netopia.com/support/hardware/2247w.html
SOURCE: How can i unlock netopia 2247NWG
Firstly... avoid showing your SSID (eircom-123456789) here, as the WEP key can be reverse engineered from the SSID.
To change your SSID, connect your router to your PC with an ethernet
cable, go to your web browser (Intenet Explorer, Forefox, etc) and type
192.168.1.254, and press return.
This will open the control panel for the router.
Select 'EXPERT MODE' from the menu on the right, and accept the warning
prompt. Then click on 'CONNECTION' and the 'WIRELESS' on the menu on
the right.
In the main window you can then change the SSID for your network.
You can also change some of the other options in this window such as
enabling closed mode, change security protocol, password, etc.
SOURCE: edimax wireless-g broadband router
please confirm if the router is a 6104K, or a KP or Wg or another model as the K and KP are not wireless, a "W" will denote wireless capability...
Not all manuals are available for download from the Edimax website but heres a start...
Connect the router to your PC with a cable... leave the modem disconnected to start with
open internet explorer and type in enter the default IP address 192.168.2.1 (broadband router’s IP address) into your PC’s web browser and press <enter>
This should bring up a user/password dialog box. By default the user name is "admin" and the password is "1234".
Confirm you are getting this far and we'll go the next steps
SOURCE: Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
