Question about Sony KLV-S32A10 32 in. HD-Ready LCD Television
I VE SONY LCD KLV-37S400A, NO PICTURE ONLY SOUND AND THE SELF DIAGONIS LIGHT BLINKS AT 6 TIMES
6ya staff
SOURCE:
leusnerdus
Leonardo Hernandez
  • 54 Answers
SOURCE: looking for a sony bravia klv-46x350a lcd spare
Usually the LCD panel cost is around 80% of total TV price. Look for it in a center of service.
Posted on Apr 20, 2010
Anonymous
  • 4 Answers
SOURCE: no picture and no sound just a blinking stand by light on front of my sony kdl40s2000 lcd tv
I called Sony repair and they said to bring my set in for evaluation. They think it is just the back light. Maybe $300 - $400 to fix. If it is the panel I will scream!
Posted on Jan 30, 2008
j4bs
  • 51 Answers
SOURCE: Sony KLV-40U100M Screen replacement
I have the same tv with no power do you want to sell me your power supply?
Posted on Apr 06, 2009
praky16
Prakash Ram
  • 744 Answers
SOURCE: sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
Posted on Apr 10, 2009
Arjun Komath
  • 1170 Answers
SOURCE: Sony LCD (Model no. KLV-26V300A), standby light
Good day.
Blinks in the indicator signifies malfunction particularly in the horizontal and vertical sections. It is sometimes caused by loose connections due to wear and tear.
If parts would be available, then there would be no such thing as obsolete boards. You can request your technician to have the degree of repair be evaluated first to determine if the expenses would justify its existence.
Your respose is highly appreciated.
Regards,
Arjun
Posted on Jun 13, 2009
Hello, I have an issue with a SONY KLV-40BX400, the TV turns on, displays the sony logo and plays the power on sound then turns off and turns on a few times and then doesnt turn at all and
If it is PLASMA TV.....
brandon barnes mentions..there is usually nothing physically wrong with 6 blink tvs..you need to reset the TV using the original remote
Not sure if the fix mentioned below is appropriate for your TV Sony eSupport Electronics Drivers Software
Aug 03, 2016 | Sony Televison & Video
TV dead. How can i fix this without replacing the whole board?
You can try the troubleshooting section of the manual here: http://www.manualslib.com/manual/440142/Sony-Klv-32s400a-32-Lcd-Tv.html?page=36#manual
Feb 04, 2016 | Sony KLV-37S400A 37 inch Multi-System HDTV...
NO VIDEO IS COMING BUT CHANNEL IS GETTING CHANGED AND SOUND IS AVAILABLE
Please check for the Back Light first. re fix the Inverter board connector. Panel may also be defective.
Nov 11, 2013 | Sony KLV-37S400A 37 inch Multi-System HDTV...
Sony KLV-46S200A LCD TV doesn't turn on, it remains blank with the red standby lighthouse blinking 4 times.
According to the service manual page 6. four flashes is "Backlight Trouble" so if its the light it self or Backlight Inverter Board i cannot tell you.
Service manual can be downloadet here.
http://elektrotanya.com/sony_klv-26s200a_klv-32s200a_klv-40s200a_klv-46s200a_chassis_wax2.pdf/download.html
Feb 03, 2013 | Televison & Video
Hi Am working on a sony lcd tv model no. KLV- 19T400A. The problem is that when I switch it on It tries to power but Enters into self diagnosis with the red LED blinking 5 times.
That is a video fault.
Five blinks
- AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video.
Feb 07, 2011 | Sony KLV32S400A 32 in. LCD TV
Turn tv on power light comes on but has no sound or picture then the standby light comes on and flashs and power light goes off
if the standby light blinks 6 times it has a bad backlite board (the most common with that set) other than that i will need to know how many times in a row it blinks. thanks....techman
Apr 01, 2010 | Sony BRAVIA KDL-52W3000 52 in. LCD...
My Sony Wega KV36XBR800 has no picture or sound, Stand by light blinks 6 times, then paus, then again 6 times. Please help. Thanks Sometimes it blinks 7 times.
ur tv chassis is DA-4 and IC 8002 is no good that is MCZ 3001D.
carefully de-solder and take IC out.
recommend use 18 pin ic socket, so u can push new IC in instead of soldering- fast and easy. do it ur self save $300. happy?
Aug 12, 2009 | Sony Televison & Video
Sony LCD (Model no. KLV-26V300A), standby light blinks 6 times. whatis the solution . No picture or sound. purchased 2 years back from India.
Good day.
Regards,
Arjun
Jun 13, 2009 | Televison & Video
Sony KLV-S32A10 32 when i turn on picture come then goes off
If the Standby light is blinking at the front panel of the TV, it seems that there is an internal malfunction occurred in the TV.
I will forward a link to a page where you can get more information and troubleshooting steps for this issue.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C399467
Please perform the steps provided on the page. If the issue still persists then service of the TV is required.
Jun 09, 2009 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Tv shuts off spontaneously. red power light blinks.
re: sony flat panel lcd tv mod. # klv s 40a10.
No power. When power button is pressed, nothing happens.
The stand-by at the power supply ( cn6201) measures to be 3.47 v. instead of 5 v. However, when I unplug cn6201 (5 pin connector) I can read 5v. at the power supply.
Any suggestions?
Jan 23, 2008 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Sony KLV-S32A10 32 in. HD-Ready LCD Television Logo
265 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
