SOURCE: Need Fuji FinePix A500 Software
Go to their website, Its a whole lot easier just to get a external card reader or use one thats built in your pc if you have one...
SOURCE: xd picture card
You will need to do a firmware update to be able to use your new 'M' XD card. Also you will need a AC adapter to be able to use the update for your camera.
It is a Fuji site and it works.
Good luck.
http://www.fujifilm.ca/x3719.xml
SOURCE: fine pix fuji S5000
i called fuji they told me that the ccd in my camera is under lifetime time warranty so i sent my camera in and they fix it free of charge goodluck
SOURCE: Problem with F470 Fine pix camera
sounds like the keypad ribbon has either popped out of it's socket or, and this would be the common fault, the ribbon has broken. In which case fuji will be your only way to fix and get it serviced at the same time. last quote I recieved was £80.
source a donor camera on ebay for the cheaper option
SOURCE: display says card not initialized when a new xd
the camera cannot use XD picture card and multimedia card (MMC). SD and SDHC can be used. for compatibility check this http://www.fujifilm.com/products/digital_cameras/accessories/card/a/
you might need to update your product depending on your serial no.
to format the card, press menu to display menu setup, press right to move to setup 2 (3rd tab) you will see Format. click Format to format the memory ("SD" is displayed if memory card is inserted and "IN" (internal memory) if no memory card. hope this helps
