Question about Alcatel One Touch FIRST 20 Cordless Phone
I am Getting an error onn the IP touch 4038 phone as stuck key
  • 486 Answers
This error message means that one of the button of the device is pressed continuously but nobody do anything with the button. You should find this button in some way. This button or key could be a function, a number or a key next to the display or an alphanumeric key too.
Try to find this key and pick up and disengage it.
I hope this helps.
Thanks.
gylacz
Posted on Sep 06, 2011
6ya staff
SOURCE:
Onn a13av502 manual
https://www.walmart.com/ip/ONN-AM-FM-Digital-Clock-Radio/45832210
Is this the same model? I haven't seen an instruction manual anywhere I searched.
Feb 16, 2018 | The Audio Players & Recorders
Error code c252
Main Motor failure to turn, PROBABLE CAUSES:
1. The main motor (M1) has failed.
Replace M1 (p/n 4038 M101 00). If the problem persists replace PWB-M (p/n 4038 0101 05 for bizhub C250 and p/n 4038 H001 01 for bizhub C252
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 27, 2014 | Konica Minolta bizhub C250 All-In-One...
How configure ip adress
Network settings are described as follows.
Touch the [Network Settings] key.
Ensure that "Enable TCP/IP is set. The IP address of the machine must also be configured using "IP Address Setting".
To enable this setting, select the checkbox and
touch the [OK] key.
Then ensure that the [DHCP] checkbox is not selected, then select each key, enter the values for the IP address with
the numeric keys, and touch the [OK] key.
May 09, 2012 | Sharp Mx27ntma Mx2300n 2700n Magenta Toner...
My Cisco IP 7960 Phone is stuck at "configuring IP"! What is happening? I need to get it fix asap :(
it would appear your phone is not getting an address from your DHCP server, i would start by plugging in a laptop to see if that gets an ip address
Hope this helps
May 21, 2011 | Cisco 7940 IP Phone
My cisco ip phone 7960 is stuck in boot up mode after performing the soft reboot. i press 123456789*0#
You can try a couple of things: Unplug the power cable from the phone, hold dows the # key, and then plug the power cable in again. The phone begins its power up cycle. Release the # key after the Speaker button is no longer lit. You should see the following message on the phone: "Reset key sequence detected" Press 123456789*0# within 60 seconds after the Headset, Mute, and Speaker buttons begin to flash. If you enter this key sequence correctly, the phone displays this prompt: Keep network cfg? 1 = yes 2 = no In order to maintain the current network configuration settings for the phone when the phone resets, press 1. In order to reset the network configuration settings when the phone resets, press 2.
Or to perform a full reset: Press **#** to reset the Cisco IP Phone 7960
Mar 15, 2011 | Cisco 7910 IP Phone
I keep getting a message F7
Error F7 is related to function keys it might be shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the oven control board (ERC).
Nov 17, 2010 | GE Ovens
Ihave internet connection but I keep getting a unknow error message on my ip phone when i try to boot it up? IT reads http:1 http://192.168.42.2 411/x 46x grade.scr HTTP 1-1 then TFPT unknown...
The phone is doing what it is supposed to do. If the phone gets to discover, then shows the phone systems IP address...
"Discover 192.168.42.1"
That means that the phone can not see the call server. Talk to the network admin
Aug 26, 2010 | Avaya 5610 IP Phone
Alcatel One Touch FIRST 20 Cordless Phone Logo
1,366 people viewed this question
Top Alcatel Lands Phones Experts
Ekse
Thomas Perkins
Thomas Perkins
ray gallant
Are you an Alcatel Lands Phone Expert? Answer questions, earn points and help others
