LG WM-2077C Front Load Washer Logo
Posted on Sep 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I rectify the UE code , I have finoished my wash but it is still showing up
Anonymous
Level 2:
Novelist:
  • Expert 154 Answers
  • Posted on Sep 06, 2011
Anonymous
Expert
Level 2:
Novelist:
Answers
154
Questions
0
Helped
54726
Points
489
Hi
UE stands for User Error.
If the water has not drained from the machine, you most likely have something caught in the water pump.
Do you have your user manual. It will guide you through clearing of the pump filter. If not let me know and I will guide you through it.
Note when you open the filter, there will be water gushing out of your machine. So be prepared with towls.
Ash
Ginko
Level 3:
  • LG Master 19,396 Answers
Ginko
LG Master
Level 3:
Answers
19396
Questions
25
Helped
8073372
Points
55462
Hi.
US means unbalanced error. Try balancing the unit as explained on the owners manual. Try redistributing the load. Check the floor. If that does not work try following the instructions in the diagrams for the specific code available on the LG support website. Here the link.
Regards.
Ginko
Keeps Stopping and saying UE
uE error code 79631512210 Kenmore Elite Washer - Sears ...
www.searspartsdirect.com > Ask an Expert
Jan 10, 2014 - uE error code 79631512210 Kenmore Elite Washer ' SearsPartsDirect. ... After unloading the washer completely, the machine attempts to rebalance the .... to ensure proper fit and to keep appliances running for years to come.
UE Error code on my front loading Kenmore washing machine
www.shopyourway.com > Manage My Life > Questions
Jun 13, 2011 - I have a Kenmore 3.5 cu. ft. front loading washing machine (model #4027) and it is 1 year old. ... what does the F35 error code on my kenmore elite front loading washing machine mean? F13 code on Kenmore Elite HE3 front loadingwashing machine.
My washing machine shows UE errors
The UE Error Code indicates that the laundry load is unbalanced. Just redistribute the load and when you shut the lid it should start to re-spin again. On some machine you have to push the start button.
LG shows code UE
the balance is controlled by the motor. if its unbalanced it usually means its overloaded or the shocks on the drum are misaligned or the springs are weak or stretched. worst case the bearing has gone. so check these.
2helpful
My 7kg LG front loader WD-80134T showed a UE error. Please can you tell me what this means and where can I get the manuel?
This is an imbalance error code. Too small of a load will cause this error code.
-Check and rebalance the load
-Make sure Washing Machine is level
-Redistribute the load evenly
What does the code s e and u e on the washing machine samsung wf8704rsw display panel.
I think you probably mean 5E. This means that there is a water drain error. To clear it, turn the POWER SW OFF and back ON.
The code UE means a load unbalance and must be manually rectified by separating the clothing. To clear the error code, use the procedure outlined above.
UE displayed on panel westinghouse 708 washing machine near end of cycle shows 6 mins left on spin then shows UE, cannot go into normal cycle.
I WOULD TRY TO LOOK AT THE DRAIN PUMP ASSEMBLY ON THE UNIT.... IT IS EITHER STOPPED UP OR NOT PUMPING FAST ENOUGH OUT DUE TO DEBRI IN THE PUMP AREA... GAIN ACCESS TO THE DRAIN PUMP AREA AND REMOVE HOSES AND LOOK INSIDE AREA.
the code data base for this is saying ue = drain failure... hope this helps you out
My Lg washer is showing a code UE and then PF what can I do to fix this problem.
UE means that the load is unbalanced in my LG. The code PE means that the water sensor is malfunctioning and needs replacing.
4helpful
Error code UE on LG F1247 TD5 washing machine
it means uneven load do u have a pillow in there or something that soaks up lots of water!!
Error code UE on LG Front Loading Washing Maching
this is what i just found on the internet...
With any washing machine, it is vital to ensure that the load is evenly balanced when using a spin cycle. Redistribute washing by adding or removing items to ensure a more balanced load. ... If the door remains locked and the machine is displaying UE error, please run a drain program.5 Jul 2016
My Samsung washing machine is showing a UE code during a spin ...
or try this link..
Error code UE on LG Front Loading Washing Maching Google Search
13helpful
My washer shows UE code
UE code is an "unbalance error". Believe it or not, it is possible to unbalance a front load style washing machine. Usually caused by trying to wash smaller loads where the drum spins to try to distribute the weight evenly. With less laundry, you cannot distribute enough weight evenly around the drum and sometimes will cause an unbalanced load. If your problem is not a simple loading issue, it could be the balance sensor, loose wiring, or possibly the main control board. I hope this helps.
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
