Neptune finished a wash load. Upon the very next load, machine was loaded, door full closed and set for Cold/cold and Delicate cycle but when start was pressed, it locked the door for 3 seconds then unlocked it. Not much time for water to get in. Pressed start again, same 3 second lock/unlock cycle, but no more water... Help ;>(
Bill
Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
Take out the inserts and rinse them and the drawer thoroughly.
Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
I have # MAH3000AWW Machine will start a fill and shut off within 3 seconds.
load completed yet when open door water pours out.
