Hitachi 50EX01B 50" Rear Projection Television Logo
laurel cranston Posted on May 16, 2006
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Re: standby mode???
My hitachi 50 rear projection tv is in what they call standby mode for some reason. The red light indicator that shows it has power is blinking.Is the tv fried for good or can it be fixed??? let me know thanks laurel
Anonymous
Level 3:
President:
  • Master 3,130 Answers
  • Posted on May 16, 2006
Anonymous
Master
Level 3:
President:
Answers
3130
Questions
5
Helped
1649970
Points
8439
No really the standby mode dosent mean the sets fried or unrepairable. It just means that the sets in a shutdown mode till a power supply problem is corrected. They have shut down protection when the power supply dosent regulate the b+ and if it didnt shut down it would give off tons of X type radiation. thats just a safty on the set. seek a pro to assist you in repairing the set. Good Luck
2answers
The power/standby indicator is flashing a red light and my tv will not turn on.
Flashing of the led light indicates an error code, count how many times it will blink to determine where the fault came from.
Jdvillanueva
I have a Sony Grand Wega rear projection TV model KDF-42WE655 and suddenly have no piucture and red light on front is blinking.
Hi.
blinking of standby light shows that your television has entered its protection mode. There may be some fault on its circuitry. Its is often called as self diagnosis indicator. Please count the number of blinks for us to help or guide you on what to do.
2answers
My sony 50" wega just quit. No picture , no sound , no nothing ?
If you see standby red light blinking on Tv front with 3 seconds interval then count its blinks from pause to pause and let me know, its an error code.
And if TV does not even show standby light then check fuse in power supply that would be blew off for some reason, replace it.
Still problem? let me know with exact model number of your Sony TV.
Thanks.
1helpful
hello if the lamp cover is not mounted securely the self diagnostic function works and the power /standby indicator flashes 3 times when you've corrected it power/standby indicator goes out the tv enters standby mode
shaun
1helpful
I got a replacement lamp, but red light still binks and there is no picture. Why?
hello if the lamp cover is not mounted securely the self -diagnostic funcation works and the power/standby indicator flashes for 3 times .when you've corrected it the power/standby indicator goes out and the tv enters standby mode
shaun
1helpful
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Tv wont show picture
Got a new tv and didn't pay any online service for a "solution"!
On and off rear projection 50''
does the red light remain on on the front? Hitachis are notorious for bad relays.
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
