Cars & Trucks Logo
Posted on Oct 04, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How i can change tire pressure sensor I recently had my CHECK SYSTEM light *yellow* come on with the exclamation point *tire pressure*. On the right side, the red triangle light with the exclamation point is on as well. The yellow tire pressure light just keeps blinking. then i changed *tire pressure sensor* but still the same nothing been change
jack layton
Level 3:
  • Lexus Master 5,569 Answers
  • Posted on Oct 04, 2017
jack layton
Lexus Master
Level 3:
Answers
5569
Questions
0
Helped
2397051
Points
20059
The new sensor has to be programmed. You probably need a scanner that can communicate with that system. Check for related trouble codes.
5 Related Answers
A
Anonymous
  • Posted on Oct 22, 2008
SOURCE: ls400 problem
The temperature sensor might be bad. I had the same problem, changed the plugs, wires, rotors, etc and nothing helped. Changed the temperature sensor and it worked fine.
ttran3279
  • Posted on Dec 01, 2008
SOURCE: VSC light &Check Engine light are on!
Try remove the battery connector from the car overnight. Plug back in the battery and see if it work. Good luck.
Anonymous
  • Posted on Jul 22, 2009
SOURCE: low pressure light staying on .
go onto your sat nav screen and select maintenance,you reset it there
Anonymous
  • 149 Answers
  • Posted on Oct 10, 2009
SOURCE: Can't figure out dashboard light
its a low tire warning light, part of your tire presure warning monitor system, its telling you one of your tires is low, check all your tires, you may have a nail in one, that info should be in your owners manual
ZJLimited
ZJ Limited
  • 17989 Answers
  • Posted on Jan 08, 2010
SOURCE: what does the warning light - yellow circle
Are refer to the Brake System; in RED and YELLOW condition, continue driving cautiously:
More details about this Warning Lights you can find in the 2003 Mini Cooper - Owners Manual (page 16 and next).
I really hope helps with this (remember rated this help) Good luck.
2answers
What a yellow Exclamation mark inside a yellow Triangle means on a Skoda Octavia 2016 mode
The yellow exclamation point close to the center of the odometer looks like an exclamation point surrounded by parentheses. This light means you should check your tire pressure. Once you have checked the air in the tires and remedied any issues, push the "Set" button on the dashboard. The light should disappear.
2answers
I has a Yellow Gear w/Exclamation Point that blinks on & off after driving a little way
When it blinks, it's telling you that you are in danger of damaging your transmission. Have the codes read.
2helpful
Yellow light on dash panel...looks like exclamation mark in circle. That blinks..what does this mean
Some cars have tire pressure sensors that can cause an indicator with an exclamation point to appear on the instrument panel.
Check the pressure in all of your tires.
Your car manual (probably crammed into your glove box somewhere) will have a diagram of all the instrument panel lights and a brief description of what they all mean.
2helpful
Yellow exclamation mark on dash
thats tire pressure its a sensor that reads your pressure and once you get low it light the dash indicator (yellow exclamation point) and if you check the pressure yourself with a tire gauge and it reads fine then you have a bad sensor.
2answers
YELLOW EXCLAMATION POINT LIGHT ON DASH. WHAT DOES IT MEAN
The yellow exclamation mark appears when your TPMS, AKA tire pressure monitoring system picks up on a low-pressure tire. It means that your tires aren't inflated to the recommended pressure. A simple fix is to inflate to the required PSI, and if the problem does not go away, drive down to the nearest garage, as you may have punctured tire at your hands.
1helpful
2answers
I have a light on my dash with an exclamation point enclosed in what looks like parenthesis with verticle lines underneath. It's yellow. Do you know what it is?
If it looks like a deflating tire with an exclamation mark inside, its the check your tire pressure light.
If its a triangle with exclamation mark inside its the check engine light.
1helpful
Exclamation point warning light came on...what
A yellow explanation point symbol on the dashboard typically applies to the Tire Pressure Monitoring system. A thick ! inside a half drawn flat tire symbol to be complete and comes in yellow color when lit. Under normal vehicle set-up, if this indicator stays lit after the power-on selftest, you need to check your tires for any uneven pressures and adjust their pressures to correct specifications. Okay? : )
A red exclamation point inside a circle when lit indicates your parking brake is on, or your brake fluid level is low.
1helpful
Yellow exclamation point on dashboard - what does it mean?
14helpful
2answers
Yellow warning light on dashboard looks like exclamation point- what does it mean car just bought no manual yet it is to the left
You have a low tire. Toyota Solaras and other Toyotas have tire sensor monitors. Go to a gas station and check the air on all of your tires including the spare. Once you get to the recommended pressure, you should be fine.
6helpful
Yellow horshoe light with exclamation point in middle
thats your TPMS light, Tire Pressure Monitoring System. The light means that one of your tires is low on air, so check them all and fill them to the specified amount, which will be located on the drivers side door jamb.
Top Lexus Experts
ROBERT GARCIA
ROBERT GARCIA
ZJ Limited
ZJ Limited
Are you a Lexus Expert? Answer questions, earn points and help others
