Remove the front panel. Observe the motor flashes.
The motor blinks on and off all the time.
It blinks faster when running.
If a failure occurs you will get the following flashes:
1 flash bad motor
2 flashes slipping belt
3 flashes corrupted software bad motor
4 flashes failed mode shift circuit
5 flashes bad motor
6 flashes locked motor check for objects between tub
7 flashes bad lid switch.
8 flashes motor overheated too much soap
9 flashes brake resister is toast bad motor.
To Reset the Inverter Board: Push the timer knob in so the washer is idle. Unplug the machine for one minute. Plug back in and raise and lower the lid six times within 12 seconds.
After resetting the inverter board, put the machine in a spin cycle and see if it runs. If not, check for a green blinking light on the inverter board. It will flash failure codes. If no light is visible you have a blown fuse built into the neutral side of the harness on the white/red wire.
If you see a small bubble in this black heat seal and the motor light is not on then the fuse within is blown replacement part is WH49X10041
What else do I have? Oh yeah how about the
SERVICE MANUAL If you need further help, reach me via phone at
https://www.6ya.com/expert/dan_73bbd84fe1d95b61
