Question about Samsung Televison & Video
LN55C630K1FXZA flashing picture - Samsung Televison & Video
I am getting different color lines thru my picture at times. My model is LN55C630K1FXZA. Version SQ01 and serial is Z1PL3CPZ200233F
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Nov 14, 2017 | Televison & Video
I have a samsung ln55c630k1fxza sqv1 has audio ,but very dim picture what can it be
switch on tv and go into menu, then check levels such as picture, brightness, if this is low change it to higher setting, it can happen if some one sat on the remote and caused setting to change. if this does not work with levels set to highest then there is some other issue with the led screen and needs checking by a technician.
I hope this was useful.
Apr 03, 2015 | Samsung Televison & Video
Black Screen
There are several things that could cause this. You could have a faulty backlight inverter(s), faulty 24V output from the power supply, failing backlight bulb(s), high voltage arcing from the inverter outputs, or a fault with the main board. I would recommend a diagnosis
Jan 15, 2013 | Samsung LN55C630K1FXZA 55 IN LCD HDTV...
How to upload pictures from computer to flash card
Follow these steps to copy pictures from computer to flash card :
Connect flash card to your computer through usb .
Then select the pictures which you want to transfer to flash card.
Then copy the pictures and go to flash card drive shown in my computer and paste it .
That's it, you have uploaded the pictures from computer to flash card .
Hope this helps .
Jan 31, 2010 | Nikon COOLPIX L3 Digital Camera
E:91:01 flashing
i also have E:91:01 flashing on my camera and when i take a picture it does not flash even when my camera is on flash
Aug 24, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
I need the flash off!
click on the flash pictures in the control square button. until you see like this line on the flash in the screen. it means flash is off
Jul 02, 2008 | Olympus FE-210 Digital Camera
Flash
make sure that there is enough light on china or a picture and please off the flash and take a picture.
since the surfaces are very smooth,the flash automatically reflects.this is called reflection of light phenomenon in physics.
so,make sure that there is enough light and switch off the flash, while you are taking a picture of that.
Mar 30, 2008 | Samsung Digimax S630 Digital Camera
When i take a picture with flash, the screen goes black and a red light flashes
after i take a picture on my nikon coolpix the screen goes black for about 30 seconds before you can take another picture.
Feb 10, 2008 | Nikon Coolpix S1 Digital Camera
Televison & Video Logo
226 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
