Ok...run unit on rinse and spin only,,we need cold water,,if unit still shows sud error make sure drain hose is not kinked,,,if we still have a sud condiction or error ,,remove toe panel and clean filter.good luck
F35 and or suds error code 95 percent of time is your pressure switch. this type of switch has a bad sensor in them and are the most common cause of this symptom.take top off," three screws on back of top and switch will be on right hand side near the back right panel. easy to replace and install. be sure to blow into the small hose before putting new one on. hope this helps.
The suds code might clear up if ya remove the service panel and clean out the pump. Behind the panel is the TECH Sheet which shows what to do about the suds problem. The F-35 has to do with water level pressure.
F-35 fix:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
After this test, it only shows C01. Then what?
you must have the machine in the test mode.
Duet service manualhttps://docs.google.com/file/d/0B5If-wTg...
press PAUSE/CANCEL to get out of diagnostics mode
