SOURCE: Samsung Over range Microwave
This is really odd. I would first suspect a setting under "My Choice" (press "My Choice" then 1, 2, 3, or 4 and check settings.
Or maybe a failing sensor.
But overriding all of this is the fact that it happens at roughly the same time each day, which is why I go back to suspecting an odd setting. Nothing in the owner's manual refers to this.
So I would recommend contacting Samsung for assistance. 1-800-SAMSUNG (1-800-726-7864), or see http:WWW.SAMSUNGSUPPORT.COM
Mine just started today too. I am thinking of taking a ball bat to it. Samsung foriegn made piece of shit.
I have the same "SE" problem. After reading this thread here, I realise it's likely the keypad problem, which explains the microwave's behaviour (no key was working).
So there were two possibilities. (1)keypad failure and (2) bad connection.
Obviously the easiest thing I could start with is to clean the connection. So I first take the cover off. Behind the keypad is a circuit board. In addition to a few connections between the circuit board and other parts of the microwave, there is a ribbon connecting the keypad to the circuit board.
Loose the plastic on the connection, pull the ribbon out from the socket. I then used spirit to clean the exposed copper connections. Put every thing back to place.
Voila, it's working again and we have been living happily ever after.....
SOURCE: my Samsung SMH7178STD gives me an error condition
Hello :
SE error means you have a shorted keypad . If you couldn't find parts , then It will be cheaper to replace the unit or have new one .
good luck .
please rate !
