I am trying to program my "Direct TV" remote to my Samsung LCD TV Series 5 and can not find the 5 digit code needed to do so.
    President:
  • 1,335 Answers
If you have a DIRECTV white remote, press "menu" then "settings," "setup," "remote", and follow the on-screen instructions.
If using a gray or black remote,
  • Make sure your TV is turned on.
  • Slide the mode switch at top of remote to "TV".
  • Press and hold the MUTE button. This is located above the number 1 button.
  • While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
  • Then enter 9911, the green light on remote should flash twice.
  • Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
  • When the TV powers off, press and release the SELECT button.
  • Posted on Sep 07, 2011
    6ya staff
    SOURCE:
    Direct TV remote control won't work with my new TV
    These are 4-digit codes : 0054, 0030, 1454, 0020. Here are 3-digit codes : 006, 007, 010, 011, 013, 016, 027, 033, 035, 043, 066, 087, 089. Try these.
    Dec 06, 2007 | Philips Magnavox 27MS343S 27" TV
    I need instructions on how to set my RCR312W for a Samsung TV, just the TV
    Hello
    There are four digit and five digit codes that can be synchronised with Samsung TV to RCR312W.
    Four digit codes are:
    1004, 1005, 1006, 1012, 1013, 1015, 1017, 1019
    Five digit codes are:
    10812, 10054, 10060, 10702, 10178
    Instructions:-
    Direct Code Entry
    To program your universal remote to control your components
    using the Direct Code Entry Method, follow the steps below.
    1. Manually turn on the component you want the remote to
    control
    2. Locate the enclosed Code Lists. Find the list for the
    component you wish to program. Find your component's
    brand. You will see a listing of four-digit codes for each
    brand.
    3. Press and hold the component key (TV,
    VCR•DVD, SAT•CBL) you wish to
    program. The illuminated ON•OFF key
    turns on and remains on. If you release
    the component key at any time during the Direct Code
    Entry procedure, the illuminated ON•OFF key blinks four
    times, and the process is exited
    4. While holding down the component key, consult the
    Code Lists for the four-digit code that corresponds to your
    component's brand and use the number keys (0-9) on the
    keypad to enter it. While you are pressing the numbers, the
    illuminated ON•OFF key turns off.
    5. After the fourth number is entered, the illuminated ON•OFF
    key turns on. At this time, release the component key. If the
    illuminated ON•OFF key turns off, you have entered a valid
    code and have followed the correct procedure for Direct
    Code Entry.
    If you enter a code number that is not in the Code Lists or
    you do not follow all of the steps for Direct Code Entry,
    the illuminated ON•OFF key blinks four times when the
    component key is released. This is an indication that a
    programming error has occurred. In that case, repeat the
    Direct Code Entry process from step 3.
    Jun 01, 2011 | RCA RCR312W Remote Control
    Need codes for olevia tv
    Olevia TV Remote Control Codes #tbltrouble TD { BORDER-BOTTOM: #cccccc 1px dotted; PADDING-LEFT: 2px }
    Remote manufactures and service providers continuously add support for new TV products. If you have the following Satellite or Cable Systems, try these remote codes for all 2 Series, 3 Series, 4 Series, 5 Series, and 7 Series Olevia HDTVs.
    Also available is the Olevia Universal Learning Remote RC-LRN that offers component programming of most video hardware including your Cable or Satellite Receivers, VCR's, Tivo's, DVD, Blue-Ray™ or even HD- DVD players.
    The learning remote is available, please call at 866-965-3842
    Satellite TV Systems Dish Network Remote Codes 506 or 127 Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 Cable TV Systems Cable Vision Remote Codes 506 Charter (Moxie Box) Remote Codes 1144 or 1178 Comcast Remote Codes 11144, 11240, 11331, 21075, 10159, 10154, or 10088 Cox (Remote Model UEI M720p01) Remote Codes 1610 Brighthouse (Remote “UEI” URC-11055) Remote Codes 1610, 1144, 1240, or 1331 Time Warner (Remote “UEI” URC-11055) Remote Codes 1610, 1144, 1240, or 1331 Time Warner (Remote "UEI" UR5L-8500L) Remote Code 432 Time Warner (Atlas OCAP 5) Remote Code 1610
    Jun 21, 2009 | Olevia LT27HVX 27 in. LCD Television
    Want to program motorola remote to samsung tv
    Samsung TV Codes: 10060, 10812, 10702, 10178, 10030, 10766, 10814, 11060, 11903.
    Hope that helps!
    Apr 10, 2009 | Motorola Mobility DRC800 Universal Remote...
    PROGRAM COMCAST DVR REMOTE TO WORK WITH TV
    Digital Lifestyles 42in 1080p FA2B-42570
    For DISH Network users: I found that the Citizen brand remote code #523 worked for the sound, mute and power. This is for the remote that comes with the standard DVR, im not sure about any others.
    ** This was added to the 32in product page because there is no listing for the 42 inch yet.
    Oct 09, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
    Program Comcast remote to operate Samsung 46"LCD
    Not sure which remote you're using. We have comcast Motorolla box and Samsung LN-T4671F. the code I used was 10812 and it works perfectly.
    Go here for more and check the comcast section:
    http://www.remotecodelist.com/remotes/
    May 18, 2008 | Samsung TV Remote Control
    Code for Vizio tv
    I contacted Vizio the other day. They tell me that they use the same generic codes as LG. I have Suddenlink Cable, formerly Charter, so I still use the Charter remote. My remote only needed 3 digits and I have noticed that many need 4 or 5. I can tell you that the LG code worked for my tv. I can power on/off, volume, and change the channel. All other functions require the manufacture's remote. The code I used is 005. There was also 004 but that did not work on my tv. Hope this helps someone!
    Dec 26, 2007 | Vizio L32 32 in. LCD HDTV
    Lcd 32" proscan need code for universal remote
    Wow it took me a couple hours but hey i found the code ever1 needs and its a 5 digit code for comcast remotes with the red ok button the codes r 10090 or 10030 hope ive helped u out good luck
    Oct 19, 2007 | Proscan 32LA30Q Television
    Televison & Video Logo
    121 people viewed this question
    Top Televison & Video Experts
    Marvin
    Marvin
