Question about Fisher and Paykel (IWL12)
Washing machine won't turn on
Firstly my Fisher & Paykal top loader SmartDrive 9 just wouldn't turn on one day - no power at all, but I had recently turned it off in the middle of a spin cycle twice in a row which I later remembered I wasn't supposed to do and put it down to that. Since March I've had a friend's Omega WD 1067 front loader and dryer, voila - all of a sudden the power won't come on! We have been using non top loader specific detergent and perhaps its been overloaded once or twice but I don't think so. It's not the electrics as the old dryer sitting next to it still works perfectly. Anyone?
  • 2 more comments
  • 59unimog411 Nov 17, 2007
    won't turn on. checked a/c outlet -ok-.
  • esteve Nov 18, 2007
    my F&P GW11 has the same problem. first it wouldn't drain, now the power is out completely. my concern is the cost of repair compaired to buying a new machine. i assume it blew a fuse but am betting a larger problem caused the fuse to blow. will i have to repair the fuse to diagnose it? any idea on repair cost?
  • rossw13 Dec 12, 2007
    Started with water not draining but replcement of diverter valve fixed that & all OK for 3 weeks. Machine again did not drain water & displayed error code 62. Turned machine off for 30 mins & on again but no change. Switched off at wall socket & drained water out manually left o'night due to other commitments switched on next morning display lights flickered but would not turn on. Holding down the power on button for a few seconds brings up error code 104. What do these error codes mean & how can I get a copy please?
  • rkchel May 12, 2008
    won't turn on. could be dead computer "brain"? If so, how to repair? Is it worth it?
For the F&P machine.
Check the circuit board fuse. I had my machine do exactly the same thing. Just wouldn't power up at all, no lights, nothing.
The fuse is on the circuit board a small round red unit, with T1.6A250V written on the top.
Remove the 2 screws securing the control panel. Inside there is a grey plastic box. This houses your circuit board. You will need to have a multi meter and a soldering iron to replace this component.
Posted on May 22, 2009
  • Jeremy
    Jeremy Oct 16, 2014
    I found the glass fuse on my F&P circuit board to be bad. Where did you buy the red fuse that you replaced on yours?
  • bsmm Oct 16, 2014
    There is no glass fuse on the model I have. But I ordered it from RS components (10 pack)
  • 641 Answers
Check power cable connector for disconnected wire. On some machines, there's a thermal fuse mounted to the exhaust duct inside the back cover panel (in a white plastic house). If the fuse has blown, it should be replaced. Good luck !!!
Posted on May 22, 2006
Sometimes the water mixing tank can spring a leak which allows water to fill up the area below the circuit board on top of the machine shorting it out intermittently. Take the top off the control panel - two screws at the back, look for water under circuit board. If it is present, remove circuit board and dry. remove water mixing tank, silicone all the joints especially the sensor hole on the top. allow slicone to dry. Put it all back togeather and it should go if you are lucky enough for the circuit board not to have fried itself. You can usually see if it has as it will have burn or scorch marks on the circuit board. Good luck
Posted on Apr 05, 2008
Omega WD 1067 washer/dryers have an over temperature stat inside that requires manual resetting if the dryer is overloaded & the temperature gets too high. To fix - UNPLUG THE POWER LEAD - remove the 2 screws from the rear top, lift the top up a little at the back & slide the lid forward to remove it.
The over temp. stat is a small rectangular box with a red button on top, push the button - if you hear a "click" it was tripped & that would have stopped the machine. Reassemble & wash-away.
If you have a copy of the operators manual please send me a scan of it.
Posted on Jul 12, 2008
Remove control unit reset little green box all go
Posted on Nov 10, 2007
6ya staff
SOURCE:
Error code 42 on fiher and paykel top loader
42. (00101010) Phase 1 - Rotor Fault
Primary Source: The Motor Controller has had some confusing information feedback.
Action: Turn off SmartDrive at the wall and back on again after 5 seconds.
Restart.
Apr 04, 2014 | Fisher and Paykel Washing Machines
I have a Fisher and Paykel Smartdrive 9 washing machine that won't fill. It starts then stops and continues to do so, then stops altogether and beeps. Can anyone help??
The error code is displayed when its beeping.
I don't know the error code, so It can only be three things,
Out of balance switch,Lid magnetic reed switch,Or Rotor position sensor,Your error code would help me work out witch one of these are faulty. to work out your error code look at picture below.
Add up the lights that are on.
Jan 08, 2013 | Fisher and Paykel Washing Machines
F & P MW511 Washing Machine ... Driving me Mad ... Please Help!
Size setting
Action - Reselect the size of Smartdrive by using the SIZE SETTING MODE. Push and hold
the water temp up button, then press the power button to enter SIZE SETTING MODE. Three
LEDs are used to identify size.
The cold water temperature LED identifies 5kg.
The low water level LED identifies 6kg.
The hold spin speed LED identifies 7kg.
If the product has not been setup before all 3 LEDs will be on.
To set the size for 5kg push the wash temp up button then
the power button.
To set the size for 6kg push the water level up button then the power button.
To set the size for 7kg push the spin speed up button then the power button.
This locks the size
into memory. To check the size is set, start a cycle.
Aug 16, 2012 | Fisher and Paykel Fisher & Paykel Washer
My fisher and paykel top loading q washing machine won't start. It beeps and lights 5 and 8 come on. Any ideas what the issue might be?
That is fault code 9 machine not sized
9. (00001000) Size Switch Error
The Display size switch setting does not match that which is stored in memory.
Action GW Machines: Reselect the size of the machine by using the SIZE SETTING
MODE.
To set the size switch, turn the power on at the power point and off at
the console. Press and hold Wash Temperature Setting Up then
press Power. SmartDrive will give 4 short beeps and the pattern of
LEDs will change.
One of the following buttons needs to be pushed to lock the size into
memory.
• Press Wash Temperature Setting Up, the Cold LED is on for 5.5kg
(560mm wide).
• Press Water Level Up, the Low Water LED is on for 6.5kg / 7.0kg
(600mm wide).
517790C
35
• Press Spin Speed Up, the Spin Hold LED is on for 7.5 / 8.0kg
(650mm wide).
• Press Power to confirm the setting and also exit this mode.
Action IW Machines: To access Size Setting Mode, push and hold the Fabric Care button
and then press the Power button to enter Size Setting mode. Select
the correct size on the display by pushing the Adjust button to
highlight the correct size. Size setting is then achieved by pressing
the Power button. Powering off will set the size into the memory.
Note: Fault code 9 will only be logged into the memory of IW machines. GW and MW
machines can display this fault but it will not be recorded.
Aug 13, 2012 | Fisher and Paykel Washing Machines
My top loading fisher and paykel q washing machine beeps with lights 5 and 8 on - what is the problem?
That is Error code 9 machine needs resizing.
MODE.
LEDs will change.
memory.
(560mm wide).
(600mm wide).
517790C
35
(650mm wide).
How do I adjust the clutch on an ELBA Model WA50T54W1 top loader washing machine ?
Hi.
Unfortunately the service documentation for Elba is not available. Although the machine has been built by F&P and although is similar to a Fisher & Paykel Smartdrive there are some small difference. The clutch system may be similar to the smartdrive. I have uploaded the service manuals for two smart drive models below, see if that can help. Check section about disassembly.
F&P top load smartdrive smI.zip
Regards.
Ginko
Sep 05, 2011 | Washing Machines
Water not coming with force in Fisher & Paykel SmartDrive Top-loa
Try taking the cold hose of at the tap and check to see if has a little mesh filter in there. This could be blocked up with gunk.
Jan 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
27,299 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
