Panasonic SDR-H85 Silver 80GB Hard Disk Drive Camcorder w/ 78x Optical Zoom Hard Drive Logo
Posted on Sep 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to delete files form my sdr-h85 - Panasonic SDR-H85 Silver 80GB Hard Disk Drive Camcorder w/ 78x Optical Zoom Hard Drive
Brian Sullivan
Level 3:
  • Panasonic Master 27,725 Answers
  • Posted on Sep 08, 2011
Brian Sullivan
Panasonic Master
Level 3:
Answers
27725
Questions
Helped
5666136
Points
79191
You will need to connect your camcorder to your computer
click start click on my computer to open from there you should see your camcorder then right click to select open you should see the data/files in there select what you want to delete right click select delete or you can right click select format this will delete all data on hard disk
hope this helps you
I have a panasonic sdr h85 i was wondering if there was any way i can record without picking up sound
https://books.google.com.pk/books?id=S_gjI7Gg3IQC&pg=PA140&lpg=PA140&dq=panasonic+sdr+h85+i+was+wondering+if+there+was+any+way+i+can+record+without+picking+up+sound&source=bl&ots=kFAJurZxv3&sig=ACfU3U0Tx7pdbg_1AxeYGxEafwjuyvJptQ&hl=en&sa=X&ved=2ahUKEwikwvu5oN7oAhWvDWMBHaCSCu8Q6AEwAHoECAwQJQ#v=onepage&q=panasonic%20sdr%20h85%20i%20was%20wondering%20if%20there%20was%20any%20way%20i%20can%20record%20without%20picking%20up%20sound&f=false
tip
Convert/Import, Edit Panasonic SDR MOD Files to Mac, iMovie, FCP
Panasonic SDR camcorder mainly contains SDR-H and SDR-S two series. Most Panasonic SDR series camcorders record videos in MOD MPEG-2 which is a standard definition video format, such as some popular Panasonic SDR camcorders: SDR-S26, SDR-S10, SDR-H60, etc. However, there are also some Panasonic SDR camcorders recording videos in AVCHD /MPEG-2 like Panasonic SDR-H86, SDR-S45, SDR-T56, etc.
To get more details of Panasonic SDR camcorders, you can check the list of most popular Panasonic SDR series camcorders as follows:
Panasonic SDR-H Series: SDR-H18, SDR-H40, SDR-H60, SDR-H80, SDR-H85, SDR-H81, SDR-H86, SDR-H200, SDR-H80S, SDR-H80K, SDR-H80A, SDR-H80R, etc.
Panasonic SDR-S Series: SDR-S10, SDR-S26, SDR-S50, SDR-S45, SDR-S150, SDR-S25A, SDR-S26K, SDR-S26R, SDR-S7K, SDR-S7A, SDR-S7R, etc.
Panasonic SDR-T and other Series: SDR-T50, SDR-T55, SDR-T51, SDR-T56, SDR-T50K, SDR-SW21S, SDR-SW21D, SDR-SW21G, SDR-SW20S, etc.
"I have a SDR H85 panasonic camcorder and can't seem to get the videos to download on my mac. Any suggestions?" ---from Yahoo Answers
Actually, for Mac users, you may have these similar problems when you want to import Panasonic SDR video to Mac, or edit these video in iMovie, or FCP, FCE. Because some Panasonic SDR series camcorder are not compatible with Mac, so you cannot directly import these camcorder videos to iMovie, Quicktime, or FCP . See here to know iMovie '09: Camcorder Support http://support.apple.com/kb/ht3290
Now, a professional Panasonic SDR Video Converter for Mac is specially designed to convert MOD(MPEG-2) to MOV, MP4, AVI, DV, H.264, 3GP, 3G2, M4V, WMV, MKV, etc on Mac. It supports converting MOD, TOD, AVCHD MTS/M2TS, etc to Mac, iMovie, Quicktime, iDVD, FCP, FCE, iPad, iPod, iPhone, Blackberry, PSP, and other popular mobile phones. This Mac MOD Video Converter can also help you extract audio from your Panasonic SDR videos to MP3, MKA, WAV, M4A, AC3, OGG, AAC, WMA, etc.
Instruction for you to convert Panasonic SDR video to Mac, iMovie, FCP, etc step by step
Step1: Install and Launch MOD Converter for Mac
Step2: Add Panasonic SDR Video on Mac
Click "Add File" to upload your chosen Panasonic SDR video to Mac MOD Video Converter after you launched it.
Step3: Set Output Video Format for Mac, iMovie, Quicktime
Click "Profile" to open the Profile drop-up list to select MOV, or MP4 as output video format for Mac OS, Quicktime, iMovie, FCP, FCE, etc.
Step4: Convert Panasonic SDR Video to Mac
Press the "Start" button to convert Panasonic SDR MOD/MPEG-2 files for Mac, iMovie, Quicktime, FCP, etc. After conversion finished, you can edit converted Panasonic SDR videos with iMovie, FCP, FCE, iDVD, etc.
More details: If you want to convert Panasonic SDR AVCHD/MPEG-2 files to Mac, you can click here to get more info of AVCHD Converter for Mac.
Related: How to get video off camcorder to Mac OS?
How to convert AVCHD m2ts/mts/ts files to MP4, MOV, DV, etc on Mac?
on Nov 05, 2010 • Computers & Internet
I have a Panasonic Camcorder SDR-H85 and I have lost the charger
I shall only reply to one of the multiple queries you have made on the same subject.
I would suggest either the mfr, or Ebay.
I would also suggest you take better care of your possessions.
I have a Panasonic SDR-T55P video camera. The battery seems to be good but the unit turns off immediately after the viewing window is open (red light is on for a few seconds). Any advice?
WHAT MESSAGE IT DISPLAYS ON SCREEN? OR WHAT IS THE RED LIGHT? IS IT THE SAME WHEN IT RECORDS?REMOVE SD CARD AND TRY USE EXTERNAL POWER SUPPLY BUT BATTERY MUST BE PANASONIC ONLY AS I SEE IT ON THE MANUAL HERE...About batteries that you can use with this unit
SDR-S50
SDR-T55
The battery that can be used with this unit is VW-VBL090/VW-VBK180/VW-VBK360.
SDR-H85
The battery that can be used with this unit is VW-VBK180/VW-VBK360.
The unit has a function for judging whether the battery can be used
SDR-H85
safely, and only dedicated batteries (VW-VBK180/VW-VBK360) support this function.
Only batteries which are genuine Panasonic products and batteries from other
companies certified by Panasonic can be used. (Only batteries which support this
function can be used) Note that Panasonic can only guarantee the quality,
performance or safety of genuine Panasonic batteries and not those made by other
companies.
It has been found that counterfeit battery packs which look very similar to the
genuine product are made available to purchase in some markets. Some of these
battery packs are not adequately protected with internal protection to meet the
requirements of appropriate safety standards. There is a possibility that these
battery packs may lead to fire or explosion. Please be advised that we are not liable
for any accident or failure occurring as a result of use of a counterfeit battery pack.
To ensure that safe products are used we would recommend that a genuine
Panasonic battery pack is used
The unit has automatically detected an error. Restart
the unit by turning off and on the power.
? Repair is needed if it is repeatedly displayed even if
it is restarted. Detach the power connected, and
consult the dealer who you purchased this unit from.
Do not attempt to repair the unit by yourself.
Is there a software download for VideoCam Suite 3.0 For Windows 7 64 bit?
This link does not work anymore. Any other thoughts on how to get a copy?
2answers
I have a panasonic sdr h85 i cant download my videos to my computer i do not have a software disk could that be the problem if so how could i get a software
-Are you using a memory card? Check "my computer" for removable drive and look for folder(s)
-Are you direct connecting via usb connection?
May need to wait for driver(s) to load to enable viewing.
What windows are you using?
Try this page: http://www.megaupload.com/?d=2U85KF1Y
Click on "Regular Download"
It's a .rar file so you'll need winrar to decompress it. Send me a personal message if you need help.
2answers
Oo.comhi. if i delete my files from SDR-H85 PANASONIC how i will recover back without problem. i did with one program but didnt help.
http://majorgeeks.com/FreeUndelete_d4407.html
FreeUndelete restores deleted files, including those removed from Windows Recycle Bin. In case of accidental removal of files on a NTFS (1.0 and 2.0) (default for Windows Vista , XP, 2000 and NT), FAT32, FAT16 or FAT12 file systems this is the utility to help.
Supported file systems:
NTFS 1.0, NTFS 2.0, FAT12, FAT16 and FAT32
The recovered files are saved into a new user-selected location to prevent overwriting the deleted files on the original media. hope this helps
Top Panasonic Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
