high speed and heavy braking will produce a pulsation in the pedal
that is the abs working properly and the pulsations are the brake release and reapplying
intermittent abs light indicates a wire or wheel sensor problem at one of the wheels
U073 is a communication code from one module to another to simply put it. Code U073 refers to a communication problem with the electronic brake control module ( Which controls ABS/Traction and stability ). I would suspect a loose connection/shorted wiring or even possible internal problem with the brake control module.If the issue occurs after hitting a bump, most likely a loose connection or the wiring rubbing somewhere causing a short from the brake control module.
The brake sensors. Cars with antilock brakes have an amber or yellow warning light, which usually says ABS. If this light stays illuminated after the bulb check, it indicates a problem with the antilock braking system. The ABS controller will disable the system and your brakes should function as if you don't have ABS. In this case, you can safely drive the car to a mechanic for service.
The parking brake problem could be rear brakes out of adjustment, a broken parking brake cable, or a parking brake cable in need of adjustment.
The ABS light mosy likely has nothing to do with your parking brake problem and will have to be diagnosed by first gathering the ABS fault codes from the ABS computer.
when brake light is constantly on it normally means the rear brake light dont work (bulb blown) ABS normally means sensors pushed too far or teeth on abs cv axle could be damaged or bent. check that first.
on certain model when the ABS light come on the brake light come on as well.
to see which sensor as set the ABS light you should have the code read with a scanner, you will be sure which sensor is defective
actually it could be something as simple as low on brake fluid. check this and then check to make sure you do not have worn brake pads on the tires this can also set a code when one tire stops quicker than the other
