Washing Machines Logo
Posted on Sep 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Hoover Optima washing machine just keeps flashing the number 35 no matter wich programme I put it on. It has done this for quite a while now but usually just messing with the control knob I could ususally fix it, however now it wont stop flashing the number 35 and 0 for the temperature. Can you advise. Thanks
Anonymous
Level 3:
Brigadier General:
  • Master 6,277 Answers
  • Posted on Sep 09, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
6277
Questions
0
Helped
1025576
Points
20216
(no promises but it's worth carrying this out anyway!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
How do I cancel wash programme on hoover optima7kg iv put wrong wash programme on but I can't seem to cancel it
I would suggest that you turn the programmer to the stop position then leave it for a few minutes and then reprogram.
Display has been playing up. A message reading 'EOS' was diplayed just now. The machine has stopped working ?
Canon DLC: Article: Canon EOS Error Messages: An ...
www.learn.usa.canon.com/resources/.../eos_error_msgs.shtml
Canon Inc.Feb 6, 2012 - Canon has installed provision to display Error Codes in EOS SLRs for quite some time. Until fairly recently, the camera could basically display a single, or limited ... today's cameras do provide a wider range of possible read-outs, giving the ....Try removing the USB cable, and firing it normally to see if it now ...
problems installing digital solution disk - Canon Community
community.usa.canon.com/t5/PowerShot/problems-installing.../225
How to Understand Hoover and Candy Washing Machine ...www.espares.co.uk > Advice CentreJul 1, 2014 - Home & Office ... If a fault is detected in your washing machine, an errorcode is likely to flash up. ... how to identify error codes in a Hoover or Candy washing machine. ... code if the machine has a problem and this will either be displayed ...Now what I'm going to do is disconnect the machine and take the ...Error message E03 - Hoover Advice Centre - Hoover Serviceservice.hoover.co.uk > Advice CentreShould the error code E3 appears it is warning that the machine is not draining. You can easily fix this problem by removing any blockages from the drain pump ...Hoover Optima Washing Machine ' OPH ' Fault Codes
1helpful
Hoover optima not displaying correct wash times
Seems that if the fault seems to be permanent it is due to failure of the PROGRAM CONTROLLER UNIT.
You will need to check on the connectors to and from the controller, clean and reset. If not replacement of the controller is the only solution.
Hoover Optima WMH 147 DF water keeps on filling up
have a Hoover OPtima washing machine WMH 147 DF. It is filling up with water and not stopping, also the panel lights and wash cycle time display are not coming on. It's only 1 old
Manual for optima 616 hoover
Hoover optima 6 kg. When I close the door it clicks shut as usual but the door security light is flashing and it wont come on. Please help.
3helpful
5answers
My Hoover Optima OPH 714 D washing machine won't start
Hope your tried switching off the machine for half to one hour, to re plug. Machine might re-set.
If helped, pl click, it could help others.
2helpful
2answers
Hoover SE230 Programmer rotating
Hi there, my washing machine was doing the same as the one you have mentioned.
I bought a replacement timer from the website highlighted below. It has done the trick and every programme works properly now.
A competent DIY person can change one of these easily and will take about 30 minutes to do.
The new part looks slightly different but it carries the same part number.
The price £24.99 + £4.98 delivery.
http://www.4hoover.co.uk/cgi-bin/product.pl?PID=723224&section=46246&brand=&model=SE230&path=45786,46246
No draining on washing machine
I am not an expert on hoover - mainly hotpoint...but..
To empty your machine of water reset the programmer to Final spin. the machine should empty normally.
On hotpoint if you have a fast flashing light its most likely to be 1 of 2 things.
1. The belt from the motor has broken. (price for belt is less than 20 pounds.)
2. The brushes in the motor have worn down too much to make the drum turn. Look underneath the washing machine to see if black power (Carbon) is deposited under the motor.
(Price for set of brushes is less than 20 pounds)
Labour should be no more than half an hour by anyone decent.
Regards
Top Washing Machines Experts
john h
