I am replacing the tray 2 feed roller old one came out easily but when trying to put new on in it doesn't appear to be snapping into place and the paper sensor just dangles. Any advice as how I know I have everything back in the right place?
Re: I am replacing the tray 2 feed roller old one came...
If you look closely, the paper sensor flag must be seated in a hard to see slot that keeps it from sliding side to side.
Be careful! Things made of plastic have a tendency to snap!
First what model? Second miss feed and jam are different, miss feed the roller can grab the paper, replace the roller putting a rubber sleave is going to mess with the feed system. Clean the rollers with alcohol
common faults for poor feeding on lj5200
1, feed rollers are worn - replace
2, sep pad is worn ( cant seperate pages correctly)- replace
3, paper empty tray sensor actuator arm snapped - unable to raise cassettetray- replace arm
4. paper feed roller fail to turn- feed unit clutch assy faulty- replace feed asseembly
5.paper tray pass guide out of position (blocking feed path) - pin that holds in place has snapped- replace feed assembly
If the Paper Feed Roller is dirty or paper powder is attached to it, paper may not be fed properly.
In this case, clean the Paper Feed Roller. Cleaning will wear out the Paper Feed Roller, so perform this only when necessary.
You need to prepare: three sheets of A4 or Letter-sized plain paper
1. Make sure that the power is turned on, and remove any paper from the Rear Tray.
2. Open the Paper Output Tray gently, and open the Output Tray Extension.
3. Clean the Paper Feed Roller.
(1) Press the (Maintenance) button repeatedly until b appears.
(2) Press the Black or Color button.
The Paper Feed Roller will rotate as it is cleaned.
4. Clean the Paper Feed Roller with paper.
(1) Make sure that the Paper Feed Roller has stopped rotating, and load three sheets of A4 or Letter-sized plain paper in the Rear Tray.
(2) Make sure that b appears on the LED, then press the Black or Color button.
The machine starts cleaning. The cleaning will be completed after the paper is ejected.
If the problem is not resolved after cleaning the Paper Feed Roller, contact the service center.
NOTE:After the cleaning is completed, press the Stop / Reset button to return the LED to the copy standby mode.
Try to inspect the paper pickup roller, on the right side of the roller you can find a small notch which gets coupled with the shaft it will be broken. You have to replace the roller.
While the line is showing up on the output pages. Stop printing and put paper in the manual feed tray (tray 1). Start printing again. As a page gets pulled into the printer about 1/2 way open the top cover. Pull out the toner and look at the page inside the printer. If it doesn't have the grey/black line, get the fuser replaced. It is defective.
Try to perform the following steps in the mentioned order:
1. Verify that the media was inserted far enough into the input tray. In
tray 2 (HP LaserJet 3390/3392 all-in-one), verify that the paper-length
guide is in the correct position for the media size that you are using.
2. Reload the media in the input tray and press
to continue the job.
The printer's pickup roller needs to be cleaned or if its worned needs to be replaced. The pickup roller is the little blue rubber roller behind the cartridge. If it still doesn't catch you'll need to strip the machine down until you get to the springs that lifts the papertray. Stretch the springs a bit. This will cause the paper to be pressed against the pickup roller. Re-assemble the machine and try it.
I had an issue with the cassette tray paper feed. I loaded paper in the rear tray, manually used the printer properties button to make it print from the rear tray and printed from there. The next day I manually did the same thing but forced it to print from the cassette (bottom) tray. It worked fine today. It no longer thinks that there is no paper and the rollers are picking up the paper edge for proper feeding of the paper. I did not go through the roller cleaning procedure but I would do that if switching back and forth manually between trays doesn't work.
CLEANING THE FEED ROLLER AND THE PAD Clean the feed roller and the pad when [391: Paper Jam] appears frequently. (1) Remove the paper cassette. (2) Clean the feed rollers (large and small) with tightly wrung wet cloth or an LED lens cleaner. Note! An LED lens cleaner is enclosed in an optional replacement toner cartridge. Feed roller (large) Feed roller (small) (3) Clean the pad on the paper cassette with tightly wrung wet cloth or an LED lens cleaner. Note! • If [392: Paper Jam] appears frequently, clean the second tray (option) in the same way. • If [390: Check MP Tray] appears frequently, clean the feed roller of the multi-purpose tray in the same way. Pad
