Try to view the properties of your cellphone memory card, if its already full you really can't save anything there. The phone memory cant be fulled because it wont opened if its already full, but if the memory card isn't full perhaps your memory card is damaged.
first thing to do is to powercycling the phone (turn off, remove battery, simcard, memory card) leave it like that for 2mins, put everything back in. if the same error occurs, try putting that memory card on another phone, if it works fine there, the phone itself maybe the one having problems. to make sure, try putting another memory card on that phone, if its all ok, they its just having a hard time reading your memory card (clean the gold contacts of the memory card by damp cotton buds, not dripping wet ok?) . if your memory card dont work w other phones, it needs to be replaced. if the phone wont read any other memory cards, bring it out for repair already and keep your memory card until phone is fixed.
Go into your camera,select settings (the gear icon) then go to the others tab, then select "save to" then choose memory card and that will automatically save all pics to the memory card automatically
First check whether the phone is configured for saving the photos to memory card or phone memory. In case it is configured for saving the photos on memory card, change it to save in phone memory and then try saving the photos. In case you are still not able to save the photos, you will have to reset the phone to factory defaults. In case you are able to save the photos in phone memory, try the memory card in another phone, if no go then you will have to format the memory card.
Hi, Just got samsung tocco, and found the soloution :-) go into camara settings, (bottom left) select pagedown, select more settings, (middle bottom) select pagedown, select default storage, select memory card and then select the save button (bottom left of screen) and your done lol....
your phone memory is low and it can't hold already the file that you are trying to save..
i suggest you to transfer all files that you want and save to memory card.
select the picture that you want and move it to memory folder.
or go to phone settings and change directly your phone memory to card memory settings.
Please be noted that your phone memory should show as a drive letter in your explorer, if not, you need to take out your memory card and connect using a card reader, or plug-in to card reader slot if there's any on your computer.
