I would recommend you to use LEO Privacy to speed up your phone, then your phone will run very smoothly, you can try it. LEO Privacy Applock Hide Safe Android Apps on Google Play
Good day. If you have a card reader, follow the simple procedures. Pull off the memory card from your phone and use the card reader and insert it on your pc. Now download the file to your pc and save it on your memory card. Then insert back the memory card to your phone from there open the file that you save and run it on your phone.If you have a cable provided by your phone unit, you can even use it as an alternative way, same procedure. Thanks
Hi
This issue usually occurs due to kinked drain pipe, clogged
drain filter or drain pump. First make sure that the drain is not clogged and
remove clogs if present. If no visible lint is present then remove the lower
front access panel to check the drain filter and drain pump for any clogs,
you'll need to clean the drain filter and drain pump completely. Hope this
helps... Please post back for any further assistance.
Daniel
Setting the Time Zone
1 Access Time Zone.
If you are unsure how to use this route map refer to Accessing Menu Items on
page 3-3.
2 Press arrow keys to select the time zone that you are in.
3 Press Enter. The message display shows Completed and returns to the Date/
Timer Set. screen.
4 Press right Select. The message display returns to the basic screen.
NOTE: Periodically check the time that is shown in the message display and adjust
as necessary to match the current time.
1 Access Year/Time.
page 3-3.
2 To set the date, for each field press arrow keys as many times as necessary to
display the correct value then press arrow keys to move to the next field.
3 When the date is correct, press Enter. The time setting screen
(hour:minute:second) is displayed.
4 To set the time, for each field press arrow keys as many times as necessary to
5 Press Enter. The message display shows Completed and returns to the Date/
Timer Set. screen.
6 Press right Select. The message display returns to the basic screen.
