Check the green paper-size end guide inside the paper tray, it may be too far forward. There's a mark for letter-size paper (LTR) and I have my guide set right at the mark even though it seems it ought to be shorter. Be sure your paper is back up against the mark. You might also buy some different paper and see if that's the problem. Sometimes cheap paper will not feed right (I use Staples copy paper in my ink jet and laser printers).
With my Brother 8840D I have had paper jams that when cleared would not delete from the display nor would the machine operate until I unplugged the machine for around eight hours. I guess it is a sort of reset or reboot.
This is a common issue. Here is the solution: Pull out the paper tray On the left of the feed roller there is a black piece of plastic that is a sensor. It is jammed forward. Gently bend it out to the left and push it back until it snaps back into place.
