HP PSC 1610 All-In-One InkJet Printer Logo
Posted on Sep 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The print cartridge carriage is stalled on HP PSC 1610 All-in-one Printer. Carriage won't go all the way to the right because of a small toggle pin.
Vinaya Kumar Kuchipudi
Level 3:
  • HP Master 1,124 Answers
  • Posted on Sep 10, 2011
HP Master
Level 3:
Answers
1124
Questions
Helped
450728
Points
2591
If you are tec guy. Open flat bed assm.. check the movement of carriage assm manually, see the obstruction, check service station.ensure that carriage should move freely..close it & check...
The print cartridge carriage is stalled.
Check to make sure that your cartridges are installed properly. Make sure that they are clicked in.
Cartridge carriage is stalled
Please let me know how install the ink cartridges blak and color.
Could I have a copyof manual pls
HP 1610 Carriage Jam
Remove the ink jet, make sure you removed any pckg. material and the contacts cover on it.
2helpful
Print Cartridge Carriage Stalled
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
3helpful
Hp psc 1610 printer ... error message alternates between carriage jam and out of paper
i cleaned the clear file strip behind the carriage by rubbing it between my fingers and my printer started working again. before that i had paper jam and carriage jam and it wouldn't do any printing or copying.
Printer Cartridge Carriage Stalls
the settings of the gears is misalligned.a technician at your place is advisable as this is a very important part of the printer if any of the arm breaks the printer may face major problems.still stick that arm with a cellow tape on it firmly and then give a print out.if the page prints properly that means it got adjusted automatically.
Print head
The most likely cause is that when you cleared the paper jam, you did something to physically misalign the print carriage. The closest thing HP has on its web site that addresses this issue is the following:
Carriage Stall Solution
See if some of the steps on this page helps. Good luck.
Remove and checl color cartridge
The problem most likely is with the electrical contact between the color cartridge and print carriage. Even if you've replaced the cartridge, if the contacts on the carriage are still dirty, it won't make a good connection with the new cartridge and the error message will still appear.
Fortunately, the HP web site has a solution posted at the following link:
Cleaning Cartridge and Print Carriage Contacts
Good luck.
Carriage Jam
You are lucky you can print ANYTHING! My unit has NEVER worked (3 years) due to a hardware defect of HP. I downloaded patches, cleaned/replaced cartridges, etc.
Spoke to HP last nite-Was told printer was junk-they don't carry it or any parts to fix it anymore!! I was told to replace it!
HP 1610 - Skipping Lines when printing w/carriage return
k24674
Grand Canyon Tech
Grand Canyon Tech
