Mitsubishi WD-62525 62" Rear Projection HDTV Logo
Posted on Sep 14, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mitsubishi tv i have a 62 inch mitsubishi dlp model#wd-62525 serial#125902 , tv will not power up it has a flashing green lite below the timer button that flashes,i have try the reset button but it just starts blinking green again.can you help me with this problem.
  • iguana523_19 Sep 25, 2008
    I have exactly the same problem with mine. It comes on and turns off after a few seconds. The lamp light is lit a constant red.
  • Anonymous Dec 01, 2008
    Same problem timer LED flashes Green, TV Won't Power on.
    I have tried to power cycle, Rest button nothing works.
    WD65733
Anonymous
Level 3:
  • Master 505 Answers
  • Posted on Dec 07, 2008
Anonymous
Master
Level 3:
Answers
505
Questions
Helped
120890
Points
1367
This is likely capacitors failing in your DM or FMT module. This model is know for the 1000uf caps going bad after 4 years or so. There are 4 on each board, plus 4 on the power supply that may go bad. You can tell by the bulging tops that are not flat. Two 3300uf caps go bad in the power supply regularly as well (this gives a lamp error). I recommend getting a service center to send the whole signal block or chassis into Mitsubishi for rebuild to get it all taken care of. The dissassembly is very difficult and frustrating. If you have tons of time and determination you could repair yourself.
Anonymous
Level 1:
Problem Solver:
  • Contributor 1 Answer
  • Posted on Sep 26, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
730
Points
I have a 62 inch mitsubishi dlp model#wd-62525 , tv will not power up it has a flashing green lite below the timer button that flashes,i have try the reset button but it just starts blinking green again.can you help me with this problem.
Anonymous
Level 1:
  • Posted on Sep 17, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
730
Points
Ok.
#1. replaced capacitors on power board. DM board FMT board .
# 2 on power board you need to chek caps. 3300mf x 35 v.QTY 2.
# 3 12 capacitor 1000mf x 16 v.
If caps 1000mf x 16 v . looked good. replaced anyway......
1 Related Answer
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: i have a 62 inch mitsubishi dlp model#wd-62525 serial#125902 , tv will not power up it has a flashing green lite below the timer button that flashes,i have try the reset button but it just starts blin
if the light just constantly blicks green and doesnt stop. You will need the" V26 DM repair kit " which will usually repair that issue. You can get the repair kit at the following link which includes the replacement capacitor and instructions
http://servicemanuals.vstore.ca/
1helpful
Green blinking timer light, TV won't turn on
Common to mitsubishi dlp tv's,you have a bad signal ***'y (power supply,formater board) lots of bad electrolytic capacitors,
Timer light blinking fast and is green, Tv will not turn on even after a reset, bulb is good
First mistake was buying Mitsubishi Model WD-62525
The DM capacitors need replacement contact a local Mitsubishi Model WD-62525repair center.
7helpful
Mitsubishi WD-62627 62" DLP TV
Try this:
1) turn on the TV
2) from the remote control press MENU 2,4,7,0 then ENTER
3) tv will state on screen that it is INITIALIZING
4) when done press the front reset button.
5) should be good to go!
TV will not turn on now after flashing green light at power button
Hi,For lcd,dlp or plasma each code is different,please list tv model.
1helpful
2answers
Timer light did not stop flash
Lamp is not the issue. It most likely is a your DM card. You most likely have some capacitors that need to be replaced. This is a terrible issue with this unit. Do a google search for "DM" and the model number and you should see hundreds of posts.
1helpful
Flashing Green "Timer" light on my Mitsubishi WD-62525
My Sony had the same problem. Unplug from the wall for 36 hours and it should solve the problem
1helpful
2answers
I have a 62 inch mitsubishi dlp model#wd-62525 serial#125902 , tv will not power up it has a flashing green lite below the timer button that flashes,i have try the reset button but it just starts blinking...
Mitsubishi 62" dlp wd-62525
The lamp is either defective, not connected properly to the wiring or plugs (careful alignment required on the two connections), wrong type bulb, or the front panel is not replaced properly to trigger the panel sense switch (lower right side of panel)
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
