Nice books, have many. 8540s./. better.
i can not decode this post.
sorry
does it run with no battery and the correct pack
mine has 10 options new the i7 and the fast video card suck huge power and mine needs a 100watt pack, the 65w on mine is HOPELESS. see?
run the correct matching pack,
step 2 a new battery, i keep 2 good ones all the time
on Vacation, id not be wanting to find batteries 3000 south of here, ever. (south of the boarder)
test with no battery
then with correct power pack (the charger is a chip inside the pc and in this 19vdc pack its only a power pack pure DC.
then try a new battery ,
if you read your service manual at HP.com
it tells you all packs used and why, and the match.
sure does.
and varies by OPTIONS DAY1. in all case
unless upgraded like mine, is, and sucks max amps mine does.
SOURCE: hp compaq nx9110 runs only on battery when it is plugged to AC
It sounds like you have a faulty power jack, and possibly a dead battery as well. You should take it to a person you may know that can order and solder a new one in or take it to your local electronics repair shop. I do repairs like this on a daily basis for my computer business.
SOURCE: Compaq nx 9020 battery charging problem
Damaged battery or internal circuit problem it is hard to to say. Bring your laptop to a repair shop. They can check the battery and tell you what the problem is.
SOURCE: HP6720s run slow when plugged in??
Start -> Control Panel -> Power Options
Ensure that when plugged-in, it is set to "Maximum Performance".
SOURCE: HP Pavillion ZV6000 - Charging Problems
hi
It seems that your laptop is not charging so in that case you must take your laptop to your vendor.For more support you can visit---------http://robs-tech.blogspot.com/2009/06/free-solution-regarding-computer.html
SOURCE: HP Pavilion dv1000 doesn't charge
You need a new system board unfortunately.
Testimonial: "it seems he's right "
