LG Shine KE970 Cellular Phone Logo
Posted on Aug 29, 2017
Call barring I am getting fed up with numbers that come through called UNKNOWN. How do I barr the phone accepting this. I only want to recieve a call that has a number or name but I do not wish to recieve a call that does not have a number. Can you help me please? Thanks my e-mail address is [email protected] and my mobile is 07722 137519
5 Related Answers
A
Anonymous
  • Posted on Jan 22, 2008
SOURCE: LG CHOCOLATE CALL BANNER
Although you can't block the call, you could save the number in your contacts, and then set the default ringtone for that contact to "No Ring"
ecurbtogo
  • Posted on May 30, 2008
SOURCE: lg rhino kg290 on tesco network
I thought Tesco Mobile used the O2 network so sim should work? Certainly used to.
Anonymous
  • 7752 Answers
  • Posted on Dec 27, 2008
SOURCE: Address Book
if it does not have the windows mobile it will not work
Anonymous
  • 113 Answers
  • Posted on Apr 25, 2009
SOURCE: barring numbers
If you have Call Blacklist facility in your handset then you can use it to block specific numbers.
If you don't have the Call Blacklist feature in your handset then ask your Operator if they provide the Call Filter services. In some regions Opertors too provide the Call Filter services.
Through Call Filter service you can manage your own Blacklist or Whitelist number. Your Blacklisted numbers will be blocked at the operator end and you will get the sms that you had a call from your such and such blacklisted number and the call is successfully blocked.
chitownbob45
chitownbob45
  • 316 Answers
  • Posted on Oct 04, 2009
SOURCE: ev2 wont let me recieve texts
lol
Call barring
go to settings and click call settings and you will see it and will be able to change that to were you get call barring
1helpful
3answers
I want o update my nokia n70 but where....?
Imagine ur cell battery is very low, u r expecting an important call and u don't have a charger.
Nokia instrument comes with a reserve battery. To activate, key is "*3370#"
Ur cell will restart with this reserve and ur instrument will show a 50% incerase in battery.
This reserve will get charged when u charge ur cell next time.
*3370# Activate Enhanced Full Rate Codec (EFR)-Your phone uses the best sound quality but talk time is reduced by approx. 5%
#3370# Deactivate Enhanced Full Rate Codec( EFR)
*#4720# Activate Half Rate Codec - Your phone uses a lower quality sound
but you should gain approx 30% more Talk Time
*#4720# Deactivate Half Rate Codec
2 *#0000# Displays your phones software version,
1st Line :S oftware Version,
2nd Line : Software Release Date,
3rd Line : Compression Type
3 *#9999# Phones software v ersion if *#0000# does not work
4 *#06# For checking the International Mobile Equipment Identity (IMEI Number)
5 #pw+1234567890+1# Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
6 #pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
7 #pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
8 #pw+1234567890+4# SIM Card Lock Status.(use the "*" button to obtain the "p,w" and "+" symbols)
9 *#147# (vodafone) this lets you know who called you last *#1471# Last call (Only vodofone)
10 *#21# Allows you to check the number that "All Calls" are diverted To
11 *#2640# Displays security code in use
12 *#30# Lets you see the private number
13 *#43# Allows you to check the "Call Waiting" status of your phone.
14 *#61# Allows you to check the number that "On No Reply" calls are diverted to
15 *#62# Allows you to check the number that "Divert If Unrea chable(no service)" calls are diverted to
16 *#67# Allows you to check the number that "On Busy Calls" are diverted to
17 *#67705646#R emoves operator logo on 3310 & 3330
18 *#73# Reset phone timers and game scores
19 *#746025625# Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it
means you will get the best standby time possible
20 *#7760# Manufactures code
21 *#7780# Restore factory settings
22 *#8110# Software version for the nokia 8110
23 *#92702689# (to rember *#WAR0ANTY#)
Displays -
1.Serial Number,
2.Date Made
3.Purchase Date,
4.Date of last repair (0000 for no repairs),
5.Transfer User Data.
To exit this mode -you need to switch your phone off then on again
24 *#94870345123456789# Deactivate the PWM-Mem
25 **21*number# Turn on "All Calls" diverting to the phone number entered
26 **61*number# Turn on "No Reply" diverting to the phone number entered
27 **67*number# Turn on "On Busy" diverting to the phone number entered
Each command is prefixed with either one or two * or # characters as follows:
** Register and Activate
* Activate
## De-Register (and Deactivate)
# Deactivate
*# Check Status
© Call button
Once each command has been entered, if it is a network command (as opposed to a local handset command) it must be transmitted to the network by pressing the YES (receiver) key which acts as an enter key - this is represented here with the © character. Always enter numbers in full international format +CountryAreaNumber ( e.g. +447712345678).
Command Description Command String
Security
Change call barring code **03*OldCode*NewCode*NewCode#©
Change call barring code **03*330*OldCode*NewCode*NewCode#©
Change PIN code **04*OldPIN*NewPIN*NewPIN#©
Change PIN2 code **042*OldPIN2*NewPIN2*NewPIN2#©
Unlock PIN code (when PIN is entered wrong 3 times) **05*PUK*NewPIN*NewPIN#©
Unlock PIN2 code (when PIN2 is entered wrong 3 times) **052*PUK2*NewPIN2*NewPIN2#©
Display IMEI *#06#
Call Forwarding (Diversions)
De-register all call diversions ##002#©
Set all configured call diversions to number and activate **004*number#©
De-register all configured call diversions (no answer, not reachable, busy) ##004#©
Unconditionally divert all calls to number and activate **21*number#©
Activate unconditionally divert all calls *21#©
De-register unconditionally divert all calls ##21#©
Deactivate unconditionally divert all calls #21#©
Check status of unconditionally divert all calls *#21#©
Divert on no answer to number and activate **61*number#©
Activate divert on no answer *61#©
De-register divert on no answer ##61#©
Deactivate divert on no answer #61#©
Check status of divert on no answer *#61#©
Divert on not reachable to number and activate **62*number#©
Activate divert on not reachable *62#©
De-register divert on not reachable ##62#©
Deactivate divert on not reachable #62#©
Check status of divert on not reachable *#62#©
Divert on busy to number and activate /td> **67*number#©<
Activate divert on busy *67#©
De-register divert on busy ##67#©
Deactivate divert on busy #67#©
Check status of divert on busy *#67#©
Change number of seconds of ringing for the given service before diverting a call (such as on no answer). Seconds must be a value from 5 to 30. De-registering the same divert will also delete this change! **service*number**seconds#© (Service numbers, see below)
Call barring
Activate barr all outgoing calls (see Security to set code) **33*code#©
Deactivate barr all outgoing calls #33*code#©
Check status of barr all outgoing calls *#33#©
Activate barr all calls **330*code#©
Deactivate barr all calls #330*code#©
Check status of barr all calls /td> *#330*code#©<
Activate barr all outgoing international calls **331*code#©
Deactivate barr all outgoing international calls #331*code#©
Check status of barr all outgoing international calls *#331#©
Activate barr all outgoing international calls except to home country **332*code#©
Deactivate barr all outgoing international calls except to home country #332*code#©
Check status of barr all outgoing international calls except to home country *#332#©
Activate barr all outgoing calls **333*code#©
Deactivate barr all outgoing calls #333*code#©
Check status of barr all outgoing calls *#333#©
Activate barr all incoming calls **35*code#©
Deactivate barr all incoming calls #35*code#©
Check status of barr all incoming calls *#35#©
Activate barr all incoming calls when roaming **351*code#©
Deactivate barr all incoming calls when roaming #351*code#©
Check status of barr all incoming calls when roaming *#351#©
Activate barr all incoming calls **353*code#©
1helpful
LG Cookie T310 - how do i bar phone sales calllers, is there a univesal pin code? The phone was sold without a maunal (which is hopeless as i have features and no way of working out how to use them!) and...
Hi,kindly click on menu key,then click on settings,then scroll to call settings,you then click on call barring,you can barr all type of calls.either;
International calls,outgoing,incoming. Etc.you then click on the one you want to activate it.that will get your calls barred.but always remember you can't barr just a number.
Take care.
3helpful
How do you remove barred from a number
You cannot barr or unbarr a single number, you can only barr a group of numbers, for instance all international incoming calls, local incoming calls, etc.
To unbarred a group of call,
Go to your phone menu,
Select your settings,
Select call settings,
Select call barring,
Select unbarred all.
And the call will be unbarred.
take care
Need to barr a number that keeps phoning me at early hours in the morning ive got an n97 and cant seem to solve this plz help!!
The easiest and fastest way to barr a number from calling you is to call your cell carrier and ask them to bar the number.
Good luck
2answers
Call Barring for 1 number
You will have to ask your phone carrier to block the number. There may be a fee, but it may not be that much. It will end the headach.
1helpful
Barring numbers
8helpful
2answers
Samsung E250 Call Barring
how i block the out going call?
Inactive sim
Did you buy your phone from someone? secondhand? Your phone is network barred it has been reported lost or stolen and the network has blacklisted the imei (serial Number) from getting onto any UK network, All the sims act differntly when placed in a barred handset some get signal but wont make or recieve a call and just make an error tone and some say "sim card registration failed" either way you phone is as good as a chocolate tea pot as the networks will not reverse the barring and the only other way to get the phone to work in the uk is to un-barr it which is changing the phones imei number which is illegal so that leaves you with one option sell the phone on ebay to someone abroad as the barr is only UK based
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
