had same problem with loading win xp proff on cf 74 toughbook mk1. soution for me was downloading sata hdd controller from panasonic toughbook support site, loading the driver onto floppy drive, using usb floppy with driver ready to use, loading win xp profesional and on first loading win screen pressing f6 when prompted at beginning of win intallation, when on screen instructions to load sata driver appeared, i followed on screen instructions and loaded 3rd option from floppy sata drive mobile driver, left usb installed untill xp loaded and running, do not remove usb floppy untill win loaded, i really hope this helps you
Hello, here are the drivers for your SAMSUNG SFD-321U External Floppy drive.
Completely free download: http://adf.ly/39ZEC After viewing the Advertisement, click at the top, SKIP AD. If the drivers worked, consider clicking on the advertisements but noting else. I might get a cent or two from it.
I sell a replacement drive for this one used in Yamaha Disklavier Pianos on E-bay. I am getting ready to list 9 of them, The address to my E-bay store is
https://www.ebay.com/str/dunnbrothersplayerpianomusic
You may have to enable 'A' drive through the bios. Depending on the bios, you need to hit F1 or F2 or F10 at initial start up. You can hit all three at once and get into the bios. Then navigate your way through the bios to find where to enable and disable drives.
I believe it's a usb connection? It should work on xp. The only problem i can think of is the driver, which should be available on their website. Is it an Imation brand?
Try plugging into windows xp and if it will ask for a driver then head over to manufacturer's site and download the appropriate driver.
If it is a USB external drive it should be recognized by your laptop, it worked for my dell floppy drive from xp to win 7 64bit, if it does not you should download the winxp driver and use it to install in win 7 when it does not recognizes the drive.
-select have drivers -select downloaded drivers
it would give you an error of pop up saying drivers are not "signed" just go ahead a accept that and it should work.
you need your windows xp disc preferably slip streamed with SP 2 or SP 3 and then you should be able to install it onto your sata hard drive.
If you are having issues then you may need to extract the sata drivers onto a memory stick or floppy disk and press F6 before windows xp loads and specify to use the sata drivers which you can download from the motherboards manufacturers website generally as a zip file which you will first need to extract into a folder.
If that does not work using the memory stick you can use nlite to slipstream the drivers with your windows xp disc : Nlite download
Hi, i have installed thousands of Internal Floppy drives and there aint no conflicts between win/95/98/me and xp.
all discs should be compatible, unless you took it from a apple machine for example.
did it work when you put in a new floppy drive?
all the best
John
