Coleman Powermate Portable Generator PM0435003 Logo
Posted on Sep 10, 2011
Coleman carburador 10hp - Coleman Powermate Portable Generator PM0435003
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 10, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
134
Points
Where i can get a Coleman carburator powermate 5000w
Wiring diagram of on/off switch. coleman 6250
coleman 6250, AC power generator gas. 10HP WX 6250???
does it matter with 2 pins, no.
I just sold one , last week.
100% perfect.
and have full documents on it. i came with manual new in box and wiring and parts list there, lost the manual did you already?
the one switch on most gens is SPST , 2 PIN SWITCH.
IT JUST KILLS SPARK..
IS THAT THE REAL MODEL # OR JUST WATTS
ALL GENERATORS HAVE TAG AND SHOWS TRUE MODELS#
Looking for a carb for a Coleman Powermate 500/6250 generator with a 10hp Briggs and Sratton engine...any suggestions?
As it is a Briggs Engine most quality Briggs dealers can get the carb. It isn't special to Coleman I don't believe.
Tecumseh model 100 engine 10hp on a coleman powermate generator it starts ok however after about 3 minutes the engine sputters like it is running out of gas and quits.
check the fuel mixture settings i believe main screw is 1 3/4 turns from closed and the idle screw is set at 1 1/4 turns from closed. These settings are for non OHV models. also check that if you have a fuel filter installed that it is not plugged up.
17helpful
What type of oil for a Coleman 5000 Generator?
You need a quart of regular old SAE 5W30 motor oil with detergent.
The engines on these generators are more or less the same as a lawn mower.
Don't forget to service/change the air cleaner when you change the oil, that should keep your generator producing full power.
Regards,
Carl
Top Coleman Electrical Supplies Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
john h
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
