SOURCE: RoadMate 700/760 Version 6 update maps are over a year old!!
THE CURE for this problem is NEVER BUY Magellan again!!
After paying over £800 for an early Roadmate 700 (which failed and was replaced by a failed/recon version) then to have problems with software.. now having waited a year to get map update and version 6 firmware I find it doesn't give me Magellan Tools which was promised by Magellan Support.
After several mail queries and important qustions remaining unanswered I am buying a Tomtom Go 720T which will do all the updates automatically via a cradle linked to my PV/Internet.
NEVER EVER AGAIN a damned Magellan - great when it works but it's easier to get blood from a stone than good support from Magellan.
SOURCE: Need to update the maps
I need to update the map on my 3225 Magellan Maestro, can anyone help?
SOURCE: Magellan Maestro 4250 2008/2009 Map Update will not update my GPS
I also had problems with a refurbished Magellan 4250. The paperwork inside said to install the 4.85 firmware update which I found would not work with Windows XP Home at least for me. I used my laptop which has Vista Ult 32 bit it updated with no problem that is so far the only solution I used.
SOURCE: Magellan Roadmate 760 map update problem
Just push the antenna firmly back into the base; it pivots on a coax connector.
This is typical when you drop it.
The antenna is removable.
