LG LHD65EBL Dehumidifier Logo
Posted on Sep 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a brand new LD651EBL. Picked it up this morning. Just plugged it in. Keep getting the CH 24 code. The bucket is all the way in. Is there a fix or do I need to return it?
Anonymous
Level 3:
Brigadier General:
  • Master 4,736 Answers
  • Posted on Sep 11, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
4736
Questions
0
Helped
2104704
Points
14643
There may be some packing material left in the bucket or tape that is holding the float valve in place. In which case, the float valve may be in the UP position, which tells the unit, that the bucket is full.
Check the top of the bucket for the float valve and make sure it's in the DOWN position. Reinstall the bucket 'squarely" in the bucket holder and making contact with the bucket safety removal switch on the rear wall of the bucket holder.
If this continues to happen, consult the Troubleshooting Guide in the Owner's Manual.
Hope this helps and thanks for choosing FixYa.
Code: CH 67
Bucket switch/float valve sticking? Take out the bucket and make sure the switch moves freely.
1helpful
Lg dehumidifier ch 67 error
Thanks for the post by Posted by Bill L on Jul 14, 2012.
I decided to take a chance and order the new Sensor assembly $20.50 and install it in my LG LD651EBL Dehumidifier which was giving me ch 67 errors. Wala, it worked, the error code is gone and the dehumidifier is now working perfectly! Thanks
Not running- CH 24 code on the Humidity setting & empty bucket red light flashing even though bucket is empty and in place correctly
If the bucket is in place correctly, turn the unit OFF & unplug it for 10 minutes. This should allow the electronics to rest and revert back to the original factory setting after you plug it back in and turn it ON. From there you should be able reset the controls to your liking.
Hope this helped. Thanks for choosing FixYa.
Just purchased Model LD651EBL - 65 pints. Followed instructions to operate/start but it will not start. Checked breakers and tried alternative plugs. Seems to be no power. What should I do?
Make sure the bucket is installed properly. It you are CERTAIN it is installed properly and you still get no power to the unit (you said you definitely have power at the wall outlet) return it to the store and either get it demo'd or replaced. Definitely rule out the wall outlet by testig with a light or a radio before you load the unit into the car.
Any more than what I have suggested may void any warranty you may be entitled to. Don"t wait.
Thank you for your question @ FixYa.com
Not running. Blinking red light for bucket full. Code flashing is CH 24.
Leo, have you removed and emptied the buck and reinstalled it? If not, that's the first thing you need to do. If you have already done that, remove the bucket and if it's equipped with a float valve in the top of the bucket, make sure the float is not stuck in the UP position. If it is, jiggle the arm of the float, so that it will return to the DOWN position.
If not equipped with a float valve, when you reinstall the bucket, be sure that it fits "squarely" from top to button into the holder.
NOTE: Before attempting any of the above, turn the unit OFF and unplug it it.
Hope this helps you troubleshoot and solve the problem.
My Dehumidifier runs fine for a few hours, then gives me the code Ch.24 and shuts off. If I unplug the unit and plug it back it it operates normally, but then will go back to that code after a while. ...
In the trouble shooting section of the manual they do list err 24 and tell you to call the service center. They will arrange a service tech to come and deal with it. Or tell you to take it back to the store.
Just so I have the data point. Do you have it hooked up to a hose or are you using the built in bucket?
6helpful
5answers
Error message CH 24. Any ideas? I have the LD651EBL dehumidifier.
We;ve managed to clear this error, at least for the last 5 days. Remove the bucket, and reach up behind the front panel where there is a filter- ours was covered in dust. After cleaning this off, and resetting the machine (by pulling the electric plug out and re-inserting), the error went away.
Your mileage may vary.
Top LG Dehumidifiers Experts
ZJ Limited
ZJ Limited
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
