Carrier 38CKC036 Air Conditioner Logo
Posted on Sep 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Compressor shuts down after 30 minute run time resets in 1hr Motor windings open after shutdown Capacitor OK pressure 70 low side, 240 liquid side Load AMP 18/18
Anonymous
Level 3:
  • Master 3,361 Answers
  • Posted on Oct 02, 2011
Anonymous
Master
Level 3:
Answers
3361
Questions
Helped
1029359
Points
10654
Check and tighten all wiring. Replace the capacitor and add a HardStart to the capacitor.Check the indoor coil for dirt/dust/obstruction. Check the outdoor fan motor for over-heating.
My carrier unit #38TKB042300 / 3794E16886 Is not cooling. The Compressor is not running. I thought maybe the capacitor might be bad so I put a new one one. The compressor comes on and runs for 3-4...
Check the running pressures and if the low side drops to low it may be shutting down on low pressure switch.I just used this as a rule of thumb. If the outside air temp is around 90 degrees then the pressures should be in the range of 60-70 on the low side.And 250-300 on the high side. If you can get the compressor to stay on then I would clean The a-coil and condensor to get maximum effiency.Thank you.
1helpful
I replaced the compressor on my refrigerator. There were no tags as to how much freon the system takes. So I added enough to bring the low side to 72 psi w/ a cabinet temp of 70 degrees. The high side...
**** boy. 72 psi on the low side? It ain't an air conditioner. The low side should be never over 5 PSI. The whole system holds only arounf 4 ounces. What were ya thankin? LOL WOW you will be lucky if the reed valves ain't blown in the new compressor. Go ahead and evacuate the system. Pull that ****** down to as close to negative 30 as you can and then shut her down. Just crack open the freon a hair and let it SLOWL:Y build to no more than 5PSI on the low side.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Accidently got 220 volts for 3 seconds, then shut off. will not re-start, how should I proceed?
Look for reset button, hopefully reset would have tripped. If compressor will not power on, remove cover to pressure switch and examine contacts for burned. If burned, temp. connect 110v to motor side of switch, (black- black and white-white) if motor runs ok replace switch. If motor does not run check capacitor for proper valve, replace as needed. If cap tests ok and motor will not run check motor windings for melted white strings that bind wiring. If windings look burned most likely you will need to find used motor from repair center.
24ABR348A0031010 compressor starts then stops. Carrier 4 ton R22 unit. Worked great, then fan runs all the time. Compressor will start for less than a minute, then stop. Basically compressor will not stay...
Hello RR Hard start can't hurt BUT dosen't sound like the problem.Do you have a scroll compressor?They don't need a kit.Does it start every time?It could be short cycling on LOW PRESSURE SWITCH.If the unit is (pumping down) during the run time you have a restriction in the system.Make sure the service valves are open ,do you have a filter dryer colgging up or a bad TXV valve also could cause short run times.20-30 PSI the switch cuts out.
Ac comes on compressor runs maybe 3 minutes than shuts off and comes on again. Does this indicate a bad compresssor?
This could be do to low on refrigerant, a dirty evaporator or filter, or a blower not running or not running at the proper speed and a low pressure switch opening due to low pressure. It also could be due to a dirty condenser or condenser fan not running or not running at the proper speed and a high pressure switch opening and shutting the compressor off. It also could be due to maybe a weak capacitor or compressor drawing high amps and the internal overload in the compressor opening and shutting the compressor off, but if that's the problem it will usually take a long time for it to restart, maybe 30 minutes to an hour or more, depending on the outdoor temperature. This really sounds like a high or low pressure issue, but needs to be checked out by a service technician.
5helpful
2answers
Ingersoll Rand SSR compressor shuts down loaded or unloaded with no alarm, and then shows ready to start . Will not run more than a few minutes either loaded or unloaded. installed meter on incoming power...
When it shuts down, press DISPLAY SELECT button once and use the up down arrows to see the code just before shutdown.
HIGH AIREND TEMP
HIGH AIR PRESSURE
LOW SUMP PRESSURE
PRESSURE OR TEMP SENSOR FAIL
CHECK MOTOR ROTATION
MOTOR OVERLOAD
FAN MOTOR OVERLOAD
STARTER FAULT
I am assuming this has a Intellisys controller.
1helpful
Will not run - compressor runs
Shut the power off to the unit, spin the fan blade to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
3helpful
3answers
LG LHD30 the compressor does not cycle on
Compressor won’t Start
The Main reasons that this will happen
1 - A bad run capacitor (silver or metal capacitor)
It’s either shorted, grounded or open.
If it’s shorted a lot of times it will bulge out, (sometimes slightly)
2 - A bad start kit ( plastic capacitor and Relay connected to it )
The capacitor is either shorted or open
The relay either has an open coil between terminals #1 and #5
Or the relay is stuck.
Any time you change the capacitor or relay you should change
the other, especially if they are over a year old.
3 - A loose, burnt or disconnected wire
4 - Wired wrong
5 Compressor is open (windings burnt open)
6 Low on charge not getting enough cooling back to compressor, (Feel top of compressor to see if it’s hot it shouldn‘t be)
7 Some compressors have a black plastic overload under the compressor cap which could be bad.
Friedrich quietmaster fan does not come on and compressor sounds like it might be laboring when switch is turned to high,medium,low cool. The airconditioner does work if the money saver switch in on. Once...
1helpful
No cold air
  1. The filter could be dirty This is the most probable cause and, of course, the easiest to check and correct.
  2. The evaporator coil face could be coated with lint,dirt, etc.Dirt or lint on the coil will restrict the flow of air through the coil and the unit must be removed from the recreational vehicle and the soil must be thoroughly cleaned with strong detergent (Coil X,Calclean, etc.) and water. Be sure to protect the fan motor and electrical controls during cleaning by covering them with polyethylene sheet. After the system is cleaned, allow it to thoroughly dry for several hours (before turning it on) to prevent electrical shorts.Before system is put back into operation, be sure the filter is properly installed to prevent recurrence of dirty coil.
  3. No compressor (Does not try to start).The compressor does not run and it does not hum.
    1.The selector switch may be open.
    2. Thermostat may be open.
    3. Overload switch may be open.
    4. Compressor winding may be open.
  4. Selector Switch
  5. Thermostat
  6. Low Voltage
  7. Overload
  8. Compressor
  9. Wiring (Mis-wired)
  10. PTCR or Potential Relay
  11. Start Capacitor
  12. Run Capacitor
To check the selector switch, remove wires from the terminals
and rotate the switch to the proper position and read
continuity as follows:
Terminals Switch Position
L-1-3 Lo Heat
L-1 Lo Fan
L-2 Hi Fan
L-1-4 Lo Cool
L-2-4 Hi Cool
Compressor Motor
The compressor motor is located inside the hermetic
compressor housing and therefore not accessible for service or
visual observation in the field. However, the motor winding
condition can be analyzed by using an ohm meter. Be sure to
remove all the leads from the compressor terminals before
making this check.
1) If the resistance between any two terminals is 0
ohms, the motor windings are shorted.
2) If the resistance between any terminal and the
compressor housing is anything but infinity, the
winding is grounded.
3) If the resistance between any two terminals is
infinity, the winding is open.
On a good compressor, the highest resistance will be between
the R (run) and S (start) terminals. The lowest resistance will
be between the C (common) and R (run) terminals. The
intermediate resistance will be between the C (common) and
S (start) terminals. Notice that compressors have the
identification of the terminals marked on either the terminal
cover or on the compressor housing.
Capacitor Check
There are several capacitor test devices available. The ohm
meter is one of them. The ohm meter cannot verify a
capacitors MFD (microfarrad) value. However, the following
procedures will show you how to use an ohm meter to
determine if the capacitor is good, open, shorted or grounded.
Before testing any capacitor, always perform the following
procedure:
* This test must be done with a analog type meter.
a) Disconnect all electrical power to the air conditioner.
b) Discharge the capacitor with a 20,000 ohm (approx.
3 watt) resistor or larger.
c) You may discharge capacitors with a standard volt
meter if you use a scale over 500 volts and touch the
leads (one lead to each side of the capacitor). The
volt meter will discharge the capacitor.
d) Identify and disconnect the wiring from the
capacitor.
e) Set and zero the ohm meter on the “highest” scale.
When testing for a good, open or shorted capacitor,
perform the following checks: Place the ohm meter
leads across the capacitor terminals (one lead on
each terminal) and perform a continuity test. Then
observe the action of the meter needle or indicator.
Reverse the leads and test again. The result should
be the same. Note: If the capacitor had not been
properly discharged, a false reading could be
indicated on the first test. Always test several times
(reversing the leads with each test). This will verify
the capacitors condition.
Good Capacitor
If the capacitor is good, the indicator will move from infinity
(the left side), towards zero ohms and slowly return back to
infinity. Reverse the leads and test again. The result should
be the same.
Start Capacitor
Most models use a start capacitor and a start relay to give the
compressor high starting torque. The compressor will,
therefore, start against normal pressure difference (head
pressure minus suction pressure) even when shut down for a
short period of time. The start relay will disconnect the start
capacitor when the motor reaches approximately 75%
running speed.
Start (Potential) Relay
The start relay consists of –
1) Normally closed contacts internally between
terminals #1 and #2 which switch in the start
capacitor in parallel to the run capacitor during shut
down and then switch out the start capacitor when
the motor reaches approximately 75% normal
running speed.
2) A high voltage coil internally between terminals #5
and #2 to actuate the contacts. The coil is too weak
on line voltage to actuate the contacts, but it is
connected in series with the start winding and it gets
the generated voltage of the start winding portion of
the compressor motor. This generated voltage is
much higher than line voltage and varies with the
speed of the motor. Therefore, since the relay is
designed to open the contacts at 75% of normal
running voltage (measured between terminals #5 and
#2), the contacts will open (thus disconnect the start
capacitor) at approximately 75% of normal running
speed.
(B) Positive Temperature Coefficient Resistor
(Commonly Known As PTCR Start
Device)
The resistor acts like a potential relay in that it takes the start
capacitor out of the start circuit, but uses resistance of
electrical flow (back EMF from compressor) instead of
opening a set of contacts. The service person should be careful
handling the resistors. They will be hot during operation (up
to 160 degrees F). The air conditioner needs to be off for 3-5
minutes during cycle time and when servicing to let the
resistor cool down.
That covers everthing.
Please rate this a fixya
Top Carrier Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
