Question about Fender 150 Watt PA System
The "PROTECT" light indicator came on and now the
    New Friend:
  • 75 Answers
The protect light generally comes on when the is a short in the speaker cabling. as a test, turn on the mixer without any speakers hooked up. If it still goes into protect mode the problem is in the mixer. Take it to your local music store and have their tech look at it. if it doesn't go into protect, check the speaker cables by plugging them in one at a time. The bad one will send it into protect.
good luck
Posted on Sep 12, 2011
Anonymous
SOURCE:
I think I may have blown the power supply on my Fender Passport 500 (Part No. 069-1001) when I inadvertently switched the power selector from 240v to 110v. I still had the power cord plugged in and the...
BAD NEG. 15V REGULATOR AND RELATED CAPS IN POWER SUPPLY.CAUSES UNIT TO GO INTO PROTECT. main supply caps and power transformer is gone. possible you'll have to trash. good success, meder's tv service
Sep 15, 2012 | Fender Passport Deluxe 500watt Sound...
We have 2 intimidator 250 intelligent lights and one of them is "stuck" on blue. We use a program called FreeStyler 512 to control them. We have restarted the computer, unplugged the lights, and...
We can only guess at the cause without tearing into the unit. My educated guess is that either the cable to the color step motor has either come loose or a wire is broken in the cable. SInce the wires go through a flexure point, that MIGHT be where the problem is... the only way to tell is to do detailed troubleshooting of the unit.
Sep 04, 2011 | Chauvet Intimidator Spot 250 Moving Light...
I own a Yamaha YPT-220 portable keyboard. The "c", "b" and "f" keys (all octaves) just stopped producing a sound. Anyone else have this problem?\r\n The dealer's service...
That's the thing with today's electronic and why warranty length is so important. Where did you buy your keyboard? It's strange that they won't fix it if it's still under warranty. My Casio CTK-2100 came with 1 year free service and they fix one key that stopped function in few days. I'm pretty sure Yamaha has the same warranty length. You sometimes have to be very persistent with them though...
Jul 18, 2011 | Yamaha Full-Size Keyboard
My passport 250 goes into protect mode on occasion. The other night at a gig it would clip into protect as soon as I sent a signal from the mic or guitar. It works fine at home. Is the unit sensitive to...
These seem to be tempermental. I would look for radio frequency interference from nearby transmitter leaking into your guitar cable or mic cable that puts this on the ragged edge of feedback. DO NOT boost highs with the EQ... You can get supersonic feedback that you can't hear, but puts the amp into limiting. Any audio input can start the feedback. These amps are VERY hard to work on due to the packaging. A lot of people have smoked their units and then require repairing.
May 24, 2011 | Fender Pd250 Passport Deluxe 250watt...
No sound coming out of speakers but lights moving on board
The Efx 12 has two outputs monitor out as well as mix out ( XLR sockets ). If the level bars are moving its an indication that the mixer is working. Have you tried headphones out as well as monitor out.
What is your amplifier and speaker setup- you have not mentioned it at all.
Even if any PFL switch is on you won't get sound out of the speakers.
PFL stands for Post Fade Listen and when any of the 12 channel PFL switch is on only the headphone out put will work.
May 18, 2011 | Soundcraft Efx12 - 12 Channel Sound Board...
The protect light is the only light that comes on
Either one of the amps or the power supply has blown. The protect light means the power supply has been shut down due to overcurrent. Take unit in for repair. These are hard to work on due to packaging.
Oct 10, 2010 | Fender Passport Deluxe 500watt Sound...
We have a Fender P-250 PA system. We get the protect light on when we turn on the system rather than the green power light. We can not get it to operate. Please advise... Gary
Likely there is either a failure in one of the power amps or the power supply. The protect means excess current is being sensed.
You need to take in for repair... these are really hard to work on due to the packaging.
Sep 23, 2010 | Fender Pd250 Passport Deluxe 250watt...
Protect light comes on when power on
This indicates either one or more of the amps have a failure OR the power supply is being overloaded which is usually also caused by failure in the amplifier.
Occasionally a power supply failure causes this problem as well.
Due to the way these are packaged, they are a real pain to work on for repairing.
Feb 19, 2010 | Fender Passport Deluxe 500watt Sound...
Fender 150 Watt PA System Logo
423 people viewed this question
Top Fender Music Experts
Michial Gueffroy
rjivaro
Larry Stiles
Larry Stiles
Are you a Fender Music Expert? Answer questions, earn points and help others
